Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac CTS Forum - 2003 through 2007
Cadillac CTS Forum - 2003 through 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
cadillac-cts
Cadillac Forums: A/C Leaking
Old 07-03-08, 11:45 PM
mickeydog's Avatar
mickeydog mickeydog is offline
Cadillac(s): Cadillac CTS 2003
View mickeydog's Photo Album
Casino Cash: $1301
A/C Leaking
Hello,I just noticed the passenger-side carpet is soaked so I called the dealer and they said the A/C drain underneath is probably plugged.Long story short that is not the problem,for some reason the condensation from the A/C is running back inside the car.Does anyone have any ideas what it could be?Thanks
  #2 (permalink)
Old 07-04-08, 01:36 AM
B Hoth's Avatar
B Hoth B Hoth is offline
Cadillac(s): 04 CTS - Lux/Blue Chip
View B Hoth's Photo Album
Casino Cash: $302
Re: A/C Leaking
Make sure that its not a bad heater core.
  #3 (permalink)
Old 07-04-08, 06:58 AM
C&C's Avatar
C&C C&C is offline
Cadillac(s): Cadillac STS (2006)
View C&C's Photo Album
Casino Cash: $6505
Re: A/C Leaking
We may need the long story because what you describe is a plugged A/C drain. (the condensation from the evaporator does run to the drain) Now, it could be a leak in the evaporator collection pan (meaning the condensation never gets to the drain hose). And, as mentioned earlier, it could be the heater core leaking; though that would have a distinct smell of antifreeze.
  #4 (permalink)
Old 07-04-08, 09:02 AM
mickeydog's Avatar
Casino Cash: $1301
Re: A/C Leaking
Sorry I was in a hurry last night,I do not think it is the heater-core,the coolant level is at full and no coolant smell inside the car.The dealer told me it is rare for a heater-core to go bad,they do not even stock it.Thanks
  #5 (permalink)
Old 07-04-08, 10:06 AM
mickeydog's Avatar
Casino Cash: $1301
Re: A/C Leaking
Hello,I just took the bottom of the dash apart and the water is dripping from the control module.Is there a seal that could have went bad or can I remove it and seal it with something then see if the leak starts somewhere else.Thanks
  #6 (permalink)
Old 07-04-08, 11:34 AM
C&C's Avatar
C&C C&C is offline
Casino Cash: $6505
Re: A/C Leaking
Another tell-tale sign of a plugged drain line would be a slushing sound from around the same area you are experiencing the drip. In any event, good hunting; hope you fine the source soon.
  #7 (permalink)
Old 07-04-08, 11:44 AM
mickeydog's Avatar
Casino Cash: $1301
Re: A/C Leaking
It is really weird when I let the A/C run now it is not leaking from the control module but it is not dripping underneath the car either.I will take it to a mechanic friend of mine and let him figure it out.Thanks and Happy 4th of July I am going golfing now......
  #8 (permalink)
Old 07-08-08, 01:31 PM
mickeydog's Avatar
Casino Cash: $1301
Re: A/C Leaking
Please help,nobody so far can figure out why the A/C is leaking water inside the car.
  #9 (permalink)
Old 07-08-08, 11:59 PM
RightTurn's Avatar
RightTurn RightTurn is online now
CAUTION!! Woman Driver
Cadillac(s): '07 3.6L CTS
View RightTurn's Photo Album
Casino Cash: $1215600
Re: A/C Leaking
Send a PM to EWILL3RD. He's a certified master Cadillac mechanic for Lindsay, and he will answer you.
  #10 (permalink)
Old 07-11-08, 09:39 AM
ewill3rd's Avatar
ewill3rd ewill3rd is offline
Cadillac Technician
Cadillac(s): none
View ewill3rd's Photo Album
Casino Cash: $9387
Re: A/C Leaking
I think we spoke via PM, here is the bulletin I was talking about.
Not really a fun one but....
Condition/Concern:
Water leaking or wet carpet below the HVAC case on the passengers side.
Vehicles built after 5/28/02, VIN 30115764 have been corrected at the plant.
Recommendation/Instructions:
Perform the following steps.
Remove passenger door sill trim.
Peel back the passenger side carpet up to the passenger seat, keeping seat in car.
Detach rear passenger foot duct from heater and A/C module (HVAC) using flat screwdriver to unsnap lock tabs, or just twist and pull the duct.
Detach wire harness from rear duct at multiple points.
Pull rear heat duct forward and remove from vehicle.
To dry out HVAC module, place control panel in foot mode, a/c off, max hot, high blower, and run for about ten minutes.
Turn off the climate control panel
Wipe off bottom of HVAC module to dry off.
From driver’s side, wedge the handle end of a skinny screwdriver between the plastic drain end and rubber tunnel insulator mat, to hold down the insulator mat.
For surface preparation of the two HVAC case seams, sand the plastic seams and follow directions on sealer tube for cleaning procedure which includes using paint thinner so as to remove any release agents or surface contamination for good RTV adhesion.
Using a tongue depressor type of wooden stick, or a paint stirrer, apply ample silicone sealer 3M Part Number 08662 or GM part number 12346192 (squeeze tube) or 12346286 (caulk gun). About a 1/4" to 1/2" bead along entire bottom of HVAC case seam, creating a continuous seal from the front side to the rear side of the case. Any missed portion will become a new leak point.
After getting the silicone on the case, use your fingers to dab the silicone upwards tight to the case.
Using only your fingers, continue the silicone 1" up the rear of HVAC case to the first screw boss.
Continue the silicone 1"-2" up the front of the case.
Pay special attention applying silicone to the bottom front of the case passenger side where the seam is lower on the driver side than it is on the passenger side.
Allow silicone one hour to dry.
Run vehicle with a/c on for a half hour to check for water under the case.
Put the car back together, making certain that the right rear foot duct is fitted into the duct outlet trim piece under the passenger seat.
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. If these steps do not resolve the condition, please contact GM TAC for further diagnostic assistance. This diagnostic approach was developed for the vehicle with the VIN you entered and should not be automatically be used for other vehicles with similar symptoms.
Models:
03 Cadillac CTS
Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group.
a or c, leaking
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
vacation travel
golf store
silver, gold, diamonds
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights
