Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac CTS Forum - 2003 through 2007
Cadillac CTS Forum - 2003 through 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
cadillac-cts
Cadillac Forums: Nav Reception/Clock Question
Old 06-25-08, 01:03 PM
zdcatc12 zdcatc12 is offline
Cadillac(s): Cadillac
View zdcatc12's Photo Album
Casino Cash: $310
I have a 2004 with Nav. When you go to the GPS info on the menu, 90 % of the time it shows only 1 or 2 satellites received. However, it appears the nav works OK. Also, the clock is set for auto update (which I assume it gets from the GPS), and is always 2-3 minutes behind. Does anybody know if this behavior is normal?
  #2 (permalink)
Old 06-25-08, 01:25 PM
xocomaox's Avatar
xocomaox xocomaox is offline
Life. Liberty. And the PURSUIT.
Cadillac(s): 2006 CTS 2.8L
View xocomaox's Photo Album
Casino Cash: $4280
Re: Nav Reception/Clock Question
18" ASA JH9 Wheels - STS-V Fogs - HID Lowbeams - HID Fogs - Drilled/Slotted Rotors
Eibach Lowered - LED Lighting - WW Sidemarkers - Navigation!! - Painted V-Grill
  #3 (permalink)
Old 06-25-08, 03:19 PM
dkozloski dkozloski is offline
Cold Soaked
Cadillac(s): 2006 STS AWD, '95 Ford Ranger
View dkozloski's Photo Album
Casino Cash: $9087
Are you out in the open or between tall buildings in a city? GPS reception is line of sight. It can be blocked by tall trees, buildings, hills, and highway overpasses.
Don't mess with Binky Bear!
  #4 (permalink)
Old 06-25-08, 11:29 PM
odysseus's Avatar
odysseus odysseus is offline
Cadillac(s): 2003 CTS Manual Trans., '93 STS
View odysseus's Photo Album
Casino Cash: $4597
Is it a factory installed Nav, or was it retrofitted later? I found that a gps antenna installed without a backplane caused these exact symptoms. Once I installed the factory gps antenna, with it's proper mounting bracket (RF Backplane), in the factory location above the instrument panel, it now picks up 6 to 8 satellites.
  #5 (permalink)
Old 06-26-08, 06:46 AM
Casino Cash: $310
It is factory installed, DVD-based maps. It appears to work right, though sometimes it is off by a little. I guess factory installed navs are also connected to the drivetrain, so it knows your speed in tunnels, etc. It happens out in the open also, not just around buildings, etc. If I watch the satellite screen every so often it will pick up more, but for the most part, when I watch the info screen, it is only picking up one or two.
I am taking it in next week and wanted to know if this a problem that needs fixed, or is it normal?
  #6 (permalink)
Old 06-26-08, 07:42 AM
Onalaska's Avatar
Onalaska Onalaska is online now
Cadillac(s): 2005 STS 1SF, 1990 Allante
View Onalaska's Photo Album
Casino Cash: $5489
If it was only picking up one it wouldn't be able to give you speed or position. Two would be way off on position, but may work to some degree. It takes three to give your exact position and accurate speed.
  #7 (permalink)
Old 06-27-08, 08:50 AM
xocomaox's Avatar
Casino Cash: $4280
I have never checked mine. But it seems to be working so why bother.
  #8 (permalink)
Old 06-28-08, 09:52 AM
odysseus's Avatar
Casino Cash: $4597
It won't lock on and give you a 2d position (lat/lon) until 3 satellites are located, at least temporarily. It also uses the VSS (Vehicle Speed Sensor) signal to get speed, so it will still show you moving on a map. This is why it works in tunnels.
While buying a 12 channel portable receiver sounds great, you only need to be locked onto four satellites for a 3D position fix (with altitude). The new 24 channel receivers are totally hype and not worth paying a dime extra for. There are only 12 visible GPS satellites at any given time, assuming best-case horizon to horizon visibility (on the ocean). Even using our rooftop antenna in our GPS lab, we've never seen more than 10 at once. Typical is more like 6 to 8.
If it is a problem, I'd suspect the antenna, or the connecting wire (built in to the antenna). Get the dealer to look at it, if it's under warranty. If not, just go get a new factory antenna (with the attached ground plane mounting bracket) for about $40 and swap them. Cheaper than buying a new Nav and finding out it was an antenna connection all along.
  #9 (permalink)
Old 07-14-08, 02:44 PM
bobat bobat is offline
View bobat's Photo Album
Casino Cash: $1066
Cool Re: Nav Reception/Clock Question
Don't know it it's "normal" or not, but it's exactly the way my stock '06 behaves. The position is always good, and the clock keeps time well enough on it's own, so I stopped thinking about it.
Tags: ,
nav, question, reception or clock
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
vacation travel
golf store
silver, gold, diamonds
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
