| Re: Wheel size help. Plz bolt pattern of a CTS is 5x115
5x114.3 will work if you use 0.7mm hubcentric rings
you can run a 10" wide wheel. others have done it, even without jacking up the rear of their cars 2 inches.
if the bolt pattern checks out, then check the offset of the wheels. i'm not sure what offset you want with a 10" wide wheel, but a search should bring about an answer.
*edit*
the 20" NAD-1 in the link you posted will not fit on the CTS, it has a 5x120 bolt pattern. If its the same size as your friends wheels, it wont fit.
__________________ Quote:
"urby and the seagulls." |
E&G Chrome Dual Mesh Upper Grille. E&G Chrome Dual Mesh Lower Grille. E&G Chrome Exhaust Tips. Escort Passport 8500 x50 Blue. Customized Volant CAI. Interior LEDs. LED Parking Lights. LED SideMarkers. LS2 STB. 2 12” Pioneer Subs. AL 1600w Amp. Clear Side Markers. Custom Eyelids. Custom Spoiler. Billet Door Locks CTS-V LS2 STB now for sale!
