Cadillac CTS Forum - 2003 through 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
 | Cadillac Forums: big time problem with my Airbag
04-20-08, 09:08 PM
|  | Cadillac Owners Enthusiast Cadillac(s): '03 White Diamond Cts | | Join Date: Mar 2008 Location: Tampa, Brandon, Plant City
Casino Cash: $2295
| | | Re: big time problem with my Airbag Very true... |
04-20-08, 09:18 PM
|  | Cadillac Owners Member Cadillac(s): 2003 Cadillac Cts | | Join Date: Apr 2008 Location: Toronto, On Age: 24
Casino Cash: $1470
| | | Re: big time problem with my Airbag yes sam it did afect the auto windows i had to reprogram them mysef to single click up/down
thanks buddy
PS: gas here in toronto is a buck 21 pre ltr so almost 5 buck on the gallon |
04-20-08, 09:33 PM
| | I SKYDIVE Cadillac(s): 03 Caddy CTS | | Join Date: Dec 2006 Location: Toronto Age: 24
Casino Cash: $1792
| | | Re: big time problem with my Airbag Quote:
Originally Posted by kissdaring hey there im new to this site just bought a 2003 cadillac cts 3 months ago and i seem to have a problem with the airbag light indication on my dash always being on, also when i pull up the codes i get 2 that can not be reset (ipc u1000 and irc u1000) i dont know if they have anything to do with the airbag.
every time i get in my car and start the engine or have it on the on possition the air bag light flashes 6 times but instead of going off and just having the seatbelt light on the seatbelt light goes off and the airbag light stays on though out my driving, i have noticed that if i play with the stering wheel before i start the car or having it on the on possition that sometimes i will go off! and i am able to clear those 2 codes mentioned above. but im not really sure if that might be the cause.
any help would be appriciated
thanks in advance | sup dude,
sorry to hear about your problem, 03's are a little buggy. I once had the airbag light come on but mine was due to low voltage when my battery died. Once it got fully charged in about 2 days it was back to normal. Also there has been similar post here before, look them up maybe it will help http://www.cadillacforums.com/forums...e-air-bag.html (Service the Air Bag!!!)
04-20-08, 10:02 PM
Casino Cash: $1470
| | | Re: big time problem with my Airbag yeah doesent look like its the harness under the seats because i unplugged them and replugged them and what do you know it went off but when i got i my car now it went back ON i think the problem comes from the front driver airbag
once again help is apriciated |
04-20-08, 10:25 PM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac | | Join Date: Jan 2008 Location: Chicago, IL
Casino Cash: $3500
| | | Re: big time problem with my Airbag It may be that harness described in by ewill3rd, however, you're not getting any codes. Here is the comment from the other thread:
It is common to have problems like this on the harness that goes from under the seat to the side air bag.
Depending on the codes of course, I usually just replace the aforementioned harness. |
04-20-08, 10:37 PM
Casino Cash: $3500
| | | Re: big time problem with my Airbag The old post mentioned a possible pinched wire in the center console, you may want to investigate that as well. |
04-21-08, 12:12 AM
Casino Cash: $1470
Originally Posted by samd It may be that harness described in by ewill3rd, however, you're not getting any codes. Here is the comment from the other thread:
Depending on the codes of course, I usually just replace the aforementioned harness. | the only cdoes i get when the airbag light is on is the 2 irc and ipc U1000 and if i try to clear codes they will not go but when i did what you told me and got the airbag light to turn off i was able to clear those 2 codes so i dont know whats going on...
as for the pinch how would i be able to get in there to some how see if thats the problem? | | Tags: air, airbag, bag, exceleration, fars, fast, indication, light, proformance, run, running, speed | | Cadillac Discussion Tools | | |
Censor is ON | | | |
