Step 1
Remove the HVAC bezels. You have to be careful, because you can
pull the bezel off of the underlying plastic.
Use a putty knife as shown below, and just work it free until
you get your fingers in there.
If it is really stuck, use a screwdriver between the bezel
and the putty knife.
There is one connector for the Hazard button on the top bezel.
The bottom bezel is the same technique, but first you have to
remove the faux ashtray, and there is a 8mm hex head screw to remove.
Unscrew it and then use pliers to get it out. If you drop it,
it will fall down behind the console and you will never get it.
Not a big loss, as I never bother to put it back in either of my CTSs.
The clips hold the bezel on just fine.
After you pry the lower bezel off, there are two connectors. The one
below for the lighter socket is a little tricky. Open the ashtray
compartment, and first pry the black clip off in the direction indicated
below. Then pry the grey connector off as indicated. Then close the
ashtray compartment and snake the thing out. There is a clip holding
the wire in place you will have to cut.
To remove the HVAC connector, first you have to remove the two grey
retainers by prying all the little tabs out and pulling the retainer
out. After that the blue connector just slides out.
Alternatively, you could leave both connectors in place, and just
let the whole bezel hang in the driver footwell. It will probably
get in your way later though.
Step 2
Remove the radio. There are four 10mm hex head screws holding the
radio in place. Remove them and the radio will slide out. There
are no clips.
Once you get the radio out, there are the two ISO connectors (brown
for the audio, grey for the power) and a yellow/green/blue data
connector. Disconnect those and the antenna.
Step 3
Switched power. We need to acquire an ignition sense 12v+ lead.
The radio does not have one. The HVAC does. First we need to make
a jumper. You will need a foot or so of wire, a splice connector,
and a bullet (or spade) connector. Strip one end as shown, and
then crimp on the bullet connector.
Next, we tap into the 12V ignition lead on the HVAC loom. CHECK
WITH A MULTIMETER OR VOLTAGE TESTER TO SEE IF THIS IS INDEED 12V+!!!
All CTSs should be the same in theory. But car manufacturers like
to change things at any given time, for no apparent reason.
On mine, it is the brown wire as shown on the connector below.
Tap into this wire anywhere on the loom (I chose to do it further
back as shown) using the wire tap and the jumper you just made.
It would be a good idea to test the continuity between the bullet
connector and the hvac connector to make sure your wire tap is
connected correctly. This will save you aggravation later in the
case that it is not.
Step 4
Prepare the Parrot kit. Below shows how all the connectors are
plugged in. There is no need at this point to plug in the mike
or button pad.
To get our switched power correctly, you need to cut the orange
wire shown below between the grey female ISO connector, and the
fuse holder.
Tape off the end from the ISO (shown by the green arrow) as it
is not needed. Add a bullet connector (opposite gender of whatever
you used on the jumper wire) to the orange wire coming from
the fuse holder.
That leaves three bullet connectors (shown by the red arrows)
that will not be used. These are for mute leads. The CTS radio
does not have phone mute in. You can cut these off, wrap them
up, or leave them hanging at your discretion.
I like things neat, so I wrapped everything up. This will also
protect the wires a little from abrasion.
Step 5 (optional)
Depending on where you choose to locate the button pad, you may
need to extend the plug for that connector. I like my control up
above the mirror. Most people just mount them on the dash or
console. If you are one of those people, your button pad cable
will be long enough and you can skip this step.
To extend the plug, cut off the 4 pin connector that is attached
via four wires to the universal plug adaptor (the 10 pin connector
that plugs into the blue box below.)
Simply get about 6 ft of 4-lead wire (or 12 ft of 2-lead wire and
twist them together as I have done) and solder the ends to each
end of the 4 wires you cut (blue, red, yellow, and black.)
