| Re: Air Compressor Newbie Look in your owner's manual. Under "Service and Appearance Care", subcategory "Electrical Systems" the 2004 has relay and fuse information. The Underhood Fuse Block has the following that seem to be related to AC:
Relay - CMP CLU RELAY MICRO - Compressor Clutch
Fuse - COMP CLUTCH - Compressor Clutch
Fuse - CCP - Climate Control
I am not sure of the exact flow, but each seems to be important to AC. I would have to study the Helm manual to fully understand. If I'm going that far, I would have to send you a bill. LOL
Assuming the 2003 is the same as my 2004: I would swap the Compressor Clutch Relay with the Fog Lamp Relay, which is right next to it. On mine, they are the same relay number. You can leave the "non-essential" item, Fog in this case, out for this test. As the manual points out, you can normally tell if the fuses are good just by pulling them and looking at the strip of metal inside. If in doubt, swap them with another non-essential fuse or a spare. Make sure to swap anything with the same type. Don't put a 30 amp fuse where a 20 amp belongs, as it is unsafe for the system.
If you end up thinking it is electrical, try to find an automotive electrical specialist in your area. These shops specialize in electrical only. In our yellow pages they are in their own section called "Auto Electric Service". I used to maintain a small fleet of vehicles. When I couldn't figure out an electrical problem myself, I took it to them. The shop that I went to was amazing and didn't gouge on prices. I've heard stories of similar great experiences at other shops.
Pittsburgh, huh. My first reaction is "that's not hot, you should try 120 degrees". But, I'm sure it is plenty uncomfortable, and more humid than our baking, dry heat. Try checking this out yourself. You will probably get to know your car better along the way. If things get too hard, deep breath, one or more ICs, and try again.
Dan |
