cadillac parts
Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac CTS Forum - 2003 through 2007
Register FAQ Donate Calendar Mark All Cadillac Forums Read
Cadillac CTS Forum - 2003 through 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
cadillac-cts
Cadillac Forums: Still need help with Infinity Kappa
Old 03-24-08, 10:10 PM
nopi08 nopi08 is offline
Cadillac(s): Cadillac
Casino Cash: $1805
I still have the 2ohm components that I want to install myself but i havent got an answer on how I wire up the crossover that comes with the speakers since the factory signal is already split at the amp. Any help would be appreciated
  #2 (permalink)
Old 03-24-08, 10:40 PM
yomommas yomommas is offline
Cadillac(s): '04 CTS, '79 Coupe DeVille, '78 Sedan De Ville, '77 Firebird
yomommas's Avatar
Casino Cash: $768
Re: Still need help with Infinity Kappa
i could be wrong, but i believe the factory crossover only splits out the sub. meaning it still sends full range to the rest of the speakers (as opposed to sending only the very highs to the tweeters). so you should be alright with running your crossover on the infiniti separates.
  #3 (permalink)
Old 03-24-08, 11:58 PM
Casino Cash: $1805
From what ive read the rear doors are the only full range and that the front doors are only midrange due to the signal being split at the amp?!?
  #4 (permalink)
Old 03-24-08, 11:59 PM
FlyFlip420 FlyFlip420 is offline
OG Blackalac
FlyFlip420's Avatar
Casino Cash: $3820
The rears are the only full range like you said......
www.diverightinscuba.com
  #5 (permalink)
Old 03-25-08, 02:05 AM
yourgmsolutions yourgmsolutions is offline
Cadillac(s): 2006 STS
yourgmsolutions's Avatar
Casino Cash: $3237
If you have components, they should come with passive x-overs. so input wire to x-over from amp, and then x-over should give you midrage and tweeter independent outputs
  #6 (permalink)
Old 03-25-08, 10:44 AM
Casino Cash: $1805
Im still confused. If I take the factory signal from the front doors and run it to the new crossover with the components, how will the tweeters get the highs from the new crossover if the crossover is just receiving a mid range signal from the factory amp?
  #7 (permalink)
Old 03-25-08, 10:50 AM
OG Blackalac
FlyFlip420's Avatar
Casino Cash: $3820
It wont.....You either need to re-wire from the midranges, or use the stock x-over....You can just, with the help of a wiring diagram, cut the wire from the amp to the tweets, and hook that up to your x-over so you dont have to re-run the wiring, but now it will be connected to the x-over. Then tap into the mids and run that to the x-over and voila....you have it all hooked up and working...only problem is that you have to turn everything to the rear and have no fade capabilities....or just use stock x-over and just replace the speakers....or just add an external ampl for $200 and call it a day and have 100x times better sound
  #8 (permalink)
Old 03-25-08, 11:56 AM
Casino Cash: $1805
Thats what i want to do then i need a cleansweep or something and then the amount i would spend would keep going up. Im no music fanatic. I just want it to sound decent at the level I listen to which is pretty low so I think this will work best for me.
vB code is On
d3 cadillac event
cadillac v-series performance cts-v, sts-v, xlr-v
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac wood grain dash kit
cadillac unlock navigation
cadillac high performance exhuast
cadillac merchandise
Powered by vBulletin® Version 3.6.10
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
