Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac CTS Forum - 2003 through 2007
Cadillac CTS Forum - 2003 through 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
cadillac-cts
Cadillac Forums: 18" Rims - Offset...and Tires?
  #11 (permalink)
Old 02-28-08, 02:06 PM
odysseus's Avatar
odysseus odysseus is offline
Cadillac(s): 2003 CTS Manual Trans., '93 STS
View odysseus's Photo Album
Casino Cash: $4622
Re: 18" Rims - Offset...and Tires?
If you go any taller than the stock V size 26.7" (245/45R18) then it will rub on the front bumper where it sits right in front of the front tire when you turn the wheel about 10 degrees. The rears will likely fit just fine. I don't know of anyone who has gone taller than that. Going to a 245/50R18 will put you almost a full inch larger. You'll rub for sure.
  #12 (permalink)
Old 02-28-08, 02:21 PM
Cartdawg Cartdawg is offline
Cadillac(s): 05 CTS
View Cartdawg's Photo Album
Casino Cash: $3514
Looks like its 245/45/18 tires then! dont want no rubbing!!!!
  #13 (permalink)
Old 02-28-08, 09:21 PM
Cadillac(s): 05 CTS
Casino Cash: $3514
What about a 225/45/18? What would that do? I really know nothing about tires man....rims...that's one thing...tire sizes an shit dont make any sense to me..
Tirerack is recommending 225/45/18 tires for an 18...
Is 225 thinner than 245???
  #14 (permalink)
Old 02-29-08, 11:29 AM
Cadillac(s): 05 CTS
Casino Cash: $3514
?????? Bueller?
  #15 (permalink)
Old 02-29-08, 11:35 AM
87vertgt 87vertgt is offline
Cadillac Owners Enthusiast
Cadillac(s): 05 Cts
View 87vertgt's Photo Album
Casino Cash: $3551
225 is skinner compared to 245...dont go with 225 as you will get curb rash. also it's easier to bend your rim with those tires..
245 45 18 or 245 40 18 is the way to go if you dont wanna go phat like me...
  #16 (permalink)
Old 02-29-08, 11:46 AM
Cadillac(s): 05 CTS
Casino Cash: $3514
ah okay...yea..I want some damn tire on the rim...so 245 it is...but what's teh 40/45 part? whats that deal with?
  #17 (permalink)
Old 02-29-08, 12:18 PM
Cadillac(s): 05 Cts
Casino Cash: $3551
oh ok....let me explain
the first number "245" is the how wide the tire is, the "40" is how tall it is and ofcourse the last number '18" is the size rim that fits inside of it....
I personally would go with 245 40 18 in front and 275 35 18 in the rear.....
  #18 (permalink)
Old 02-29-08, 12:57 PM
Cadillac(s): 05 CTS
Casino Cash: $3514
lol...i'm nnot gettin seperate tires......no way
  #19 (permalink)
Old 02-29-08, 12:59 PM
kfx's Avatar
kfx kfx is offline
Cadillac(s): 2003 Cadillac CTS
View kfx's Photo Album
Casino Cash: $2327
Here is a previous quote from Ody that I saved when I was shopping for wheels/tires that gives an awesome explanation of tire sizing:
"The math goes like this: example - 245/45R18 : 245 is the tire width in millimeters. You can convert this to inches by dividing by 25.4mm/in (9.65" wide)
45 is the sidewall dimension in percent, with respect to the tire width. 9.65" (from the previous calculation) x .45 = 4.34".
Since there are two sidewall heights for any given wheel diameter (one touching the ground and the other on the top near the fender), you simply add two tirewall heights to the rim diameter (18" in this case). 4.34 + 4.34 + 18 = 26.69". This is the standard factory tire size for the CTS-V which is the same body as the V6 models. We know this fits fine with the factory V offset of 42mm. From experience, 40mm also fits, since it's <1/10" further toward the fenders. You can calculate the new height of different tires using the same formula, and comparing it (or simply use one of the on-line tire size calculators).
Offset, is the distance from the centerline of the wheel/tire to the lug mounting surface. 245's are the widest you're gonna fit on the front and not hit the upper A-arm pinch bolt on the inside, or the fenders on the outside (40-45mm offset generally is what's required). On the rear, if you want to go wider, you'll need to add all of the additional width to the inside of the wheel, since the outside is too near the fenderwell. Going to a 275 series tire, means an additional 30mm (compared to the example 245 series above). Adding 30mm to the inside only moves the centerline half of that amount, or 15mm. 40mm + 15mm = 55mm offset. One must measure very very carefully first, to make sure you have 30mm to spare before you rub the lower a-arm brace in the rear, since it's going to be very close. If it's gonna hit, then you'll need to shift it outward 5mm (to 50mm) or so and roll the fender seams. 275's are a tight fit, but it's been done several times. One needs to maintain the same sidewall height/tire diameter, which means going to a lower series tire (275/40R18).
Positive offset (bigger numbers) move the wheel inwards toward the body. Smaller positive numbers and negative offset (big lips) move the wheel outward toward the fenders. Most modern cars cannot use negative offset, since the wheels would be way outside of the fenders."
I have 18's and remember also in previous thread from Robert that if you run 245/45/18 your speedo will still be accurate because it will give you that 26" tire height that yer tryin to maintain.
  #20 (permalink)
Old 02-29-08, 01:36 PM
Cadillac(s): 05 CTS
Casino Cash: $3514
Wow.....thanks! But damn..That TOO much info..lol I just wanna know..what i can put on my car..so that the tires aint paper thin...and take up the most space so there isn't a huge gap from the wheel to the fender....and so that it dont rub.....
That's all.....lol
Tags: , , ,
offsetand, rims, tires
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
vacation travel
golf store
silver, gold, diamonds
cadillac fuel doors
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods | cadillac accessories | cadillac wheels | cadillac performance parts | cadillac cts accessories | tail lights
