| Re: replacement battery for '04 It is designed for a 101 series battery, no one else is making 101 batteries as far as I have seen.
You can go with a Delco. I recommend staying away from the optimas unless you can get one without top posts.
People have been creative about installing them, but the fact of the matter is that it can hit the hood and be a real potential fire hazard. You can search for discussions on that.
I have seen some folks put a 78 series battery in with some degree of success, those are readily available from almost any battery manufacturer.
Not sure if you have to modify the tray and I think it will be pretty tight under the cowl.
__________________ Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group. |
