Cadillac CTS Forum - 2003 through 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
 | Cadillac Forums: Called Dealer About Recall
02-11-08, 10:10 PM
|  | Cadillac Technician Cadillac(s): none | | Join Date: Nov 2005 Location: Alexandria, VA Age: 40
Casino Cash: $9387
| | | Re: Called Dealer About Recall Can you estimate the size of these bearings?
Not many things on GM cars use an actual "ball" bearing.
None that you might find on the floor I can think of.
__________________ Views expressed by the author of this post do not necessarily represent those of the Lindsay Automotive Group. |
02-29-08, 09:11 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | Join Date: Aug 2007 Location: Maryland
Casino Cash: $300
| | | Re: Called Dealer About Recall Hey, thanks for all of your advice on the forum.
I took my "04 CTS w/85K to the dealer yesterday w/whine, told me today I need $1,800 repair to replace bearings in differential. Is mine too old for GM reimbursement? I love the car but afraid of repeat repairs.
Is it a simple fix?  |
03-01-08, 09:39 AM
|  | Cadillac Owners Member Cadillac(s): 2004 CTS | | Join Date: Feb 2008 Location: Springfield VA
Casino Cash: $760
| | | Re: Called Dealer About Recall Quote:
Is it a simple fix?  | Only 05 and ups are covered by the recall, I have a 04 myself. But what month was your car made? Also was the rear seal ever leaking? If late 04 (like a month before it was called a 05) and/or if the rear seal was replaced under warranty then you can call cadillac and they MIGHT help. They caddy, know of this problem so they might cover it or offer a discount. |
03-01-08, 11:33 AM
Casino Cash: $9387
| | | Re: Called Dealer About Recall Putting bearings in the rear diff? Nothing "simple" about it.
Not sure if you can do much to get them to help you with that many miles on it.
Just make sure they are going to stand behind their work, meaning... if they do the fix, and the car still makes the noise, who pays for the next attempt? |
03-02-08, 02:39 PM
| | Cadillac Owners Connoisseur Cadillac(s): Sedan de Ville, CTS | | Join Date: Mar 2007 Location: San Antonio, Tx
Casino Cash: $2469
Originally Posted by ewill3rd First of all, this has been talked about A LOT on the forum already.
Next, the problem is a leaking differential seal, if you see a leak, get it fixed... if you are out of warranty I can almost guarantee that GM will have a repair cost reimbursement process. If you are in warranty, take the thing in to get it fixed for free, if it is leaking there is a current bulletin on how to fix it.
If it isn't leaking, what is to freak out about?
The whole issue is based on a leak.
Half the underside of the car will be covered with differential lubricant before any damage will occur to the rear drive axle.
If you are actually concerned about it, have them raise the car and verify that the differential is properly filled and take a valium.
Lastly, for you guys in the cheap seats.... THE RECALL HASN'T EVEN BEEN RELEASED YET.
Here is some text from a news website:
I am not sure what calendar some of you are using, but mine says it is still JANUARY. On Earth, we use a concept called "linear time". That means we can't access February until January is completed. When March gets here and your car still hasn't been fixed, then maybe I could see what the complaint is here. | Well stated. |
03-02-08, 06:07 PM
Casino Cash: $9387
| | | Re: Called Dealer About Recall Thanks, but actually the recall is well underway now! LOL
Now the issue is there are no parts anywhere.  |
03-03-08, 03:24 AM
| | Cadillac Owners Member Cadillac(s): 2006 Cadillac CTS 6MT, 2008 Cadillac CTS 6MT | | Join Date: Nov 2007 Location: Ontario, Canada Age: 24
Casino Cash: $3165
| | | Re: Called Dealer About Recall Had my '06 CTS 6MT into the dealer for an annual inspection about a week ago, and they notified me of the recall. They explained my vehicle was included, so I told them to go ahead and repair it. Ever since, I have had a "rumbling, roaring" noise in the rear during turns with no acceleration. As soon as I hit the gas, the sound disappears. The sound is almost deafening. I have an appointment to bring it in Tuesday to the dealership. I have the sport package (which includes a limited slip diff.). Does this matter? I am positive I read in the manual that the "limited slip diff" requires a certain amount of "limited slip diff" fluid? Could it be possible the tech forgot to add "limited slip diff" fluid while filling it back up? Anyways, just looking to see if anyone else has had this problem, or if anyone can give me a heads up on what is going on... thanks in advance! |
03-03-08, 06:27 AM
|  | Cadillac Owners Fanatic Cadillac(s): Cadillac STS (2006) | | Join Date: Feb 2008 Location: Mount Pleasant, SC Age: 58
Casino Cash: $6505
| | | Re: Called Dealer About Recall Fritze, as you were describing your problem I was thinking the same thing; probably didn't add the limited slip 'special' fluid. Hopefully that's all your problem is. If not, I'm sure they will still fix your car under the guidelines of the recall as you didn't encounter the problem till after they replace the seal. |
03-03-08, 07:44 AM
Casino Cash: $9387
| | | Re: Called Dealer About Recall fritz, I'd bet money they didn't add any friction modifier.
Take it back and remind them. |
03-03-08, 08:47 AM
Casino Cash: $3165
| | | Re: Called Dealer About Recall Thanks guys! I'll mention about the fluid Tuesday when I take it in. I will keep you posted! | | Cadillac Discussion Tools | | |
Censor is ON | | | |
