Throwing code P0128 -- 2003 3.2 L - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 37 of 37
Like Tree1Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Throwing code P0128 -- 2003 3.2 L in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Thread helped alot. Almost a 9 year thread!...
  1. #31
    stanced03 is offline Cadillac Owners Member
    Automobile(s): 03 CTS
    Jul 2013
    28
    10
    Re: Throwing code P0128 -- 2003 3.2 L
  2. #32
    Ikera's Avatar
    Ikera is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac CTS 3.2, 1990 Nissan 240sx Turbocharged
    Apr 2013
    Vancouver, BC
    30
    383
    FYI The thermostat housing breaks almost as often as the thermostats themselves, (bracket that holds the t-stat inside the housing breaks) better to replace both
  3. #33
    streetglidecody07's Avatar
    streetglidecody07 is offline Cadillac Owners Member
    Automobile(s): 03 cts
    Aug 2013
    Norwalk, Ohio
    3
    OK guys I have an issue with the p0128 code I'm scratching my head on. Car is an 03 cts manual I replaced tstat in march amf the radiator 2 months ago as it was leaking. Now the code is back and I have an issue getting heat. Has anyone experienced this!? Could a clogged heater core throw a p0128?
  5. #34
    Ikera's Avatar
    Apr 2013
    Vancouver, BC
    30
    383
    Quote Originally Posted by streetglidecody07 View Post
    I don't think the clogged heater core could cause this code, but a trapped air in the system could cause both, the code and no heat in the climate control.
    rev the engine fast couple of time see it make heat come back and check you coolant level
  6. #35
    cabletech is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS 3.2L M35 LtPt
    May 2010
    223
    Mine's back again, BTW. lol. I'll clear it out when the weather warms back up. I replaced the thermostat early this year when I did the timing belt job. No difference. Car ran fine all summer. I think that some 3.2L motors just have a problem warming up in the winter.
    CTSjones likes this.
  7. #36
    Aug 2013
    Norwalk, Ohio
    3
    I'm starting to agree with cabletech because I thought it was just air in system after changing radiator maybe but I tried burping it a couple times with no luck. Its been about a month now n no luck. I may be wrong but I swear I came across an article that said po128 could be caused by bad heater core. Also what t stat did you use? I tried the autozone and just wondered if maybe anyone had issues with them?
  8. #37
    mattkensil is offline Cadillac Owners Member
    Feb 2013
    12
    I have an 03 CTS and have been getting the P0128 code. i replaced the t-stat, coolant temp sensor, coolant bypass valve and fixed some vacuum issues, but still keep getting the code. could someone explain the burping thing to me, havent heard that one before. also, any other ideas? should i do a complete system flush?
  9. Remove Advertisements
