Throwing code P0128 -- 2003 3.2 L - Page 2
Results 16 to 30 of 37
Like Tree1Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Throwing code P0128 -- 2003 3.2 L in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Where can i get the PDF file? im curious to know what this procedure is going to take... I'm having ...
  1. #16
    FlyingRaven's Avatar
    FlyingRaven is offline Cadillac Owners Fanatic
    Automobile(s): balck raven 2003 CTS
    Nov 2007
    36
    134
    Re: Throwing code P0128 -- 2003 3.2 L
    Where can i get the PDF file? im curious to know what this procedure is going to take... I'm having the same code.
  2. #17
    Roki is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Jan 2008
    QuestionRe: Throwing code P0128 -- 2003 3.2 L
    Can you tell me do I need some aditionnal parts , like gasket or something else, when changin termostat.
    Thanks
  3. #18
    the cadillac kid's Avatar
    the cadillac kid is offline Cadillac Owners 10000+ Posts
    Automobile(s): > BMUU
    Mar 2007
    jersey
    14,388
    open the Attached File at the bottom of this guy's post: http://www.cadillacforums.com/forums/974075-post2.html
  5. #19
    RunningOnEMT's Avatar
    RunningOnEMT is offline Cadillac Owners Master
    Automobile(s): 05 Redline CTS-V
    Aug 2005
    Lansdowne, VA
    35
    8,439
    http://myweb.accessus.net/~090/dtcobd2.html
    best GM OBDII reference i've found in years
  6. #20
    justfishing41 is offline Cadillac Owners Member
    Automobile(s): Cadillac 2003 CTS
    Mar 2008
    Green Bay, Wisconsin
    Hi guys! I just joined so be gentle.
    I just bought a used 2003 CTS in Nov. 2007 with 47,000 miles and have been pretty happy with it so far. I resently started getting the same check engine light. I drove with it for a couple weeks and it did go out for a coule weeks but came back on. It's been anything but warm up here in Green Bay and had the dealer check it and they want to replace the thermostat for $335 ($255 labor, $50 parts, $30 misc/tax). The light was out after I got it back form the dealer but came on again after a couple days.
    My dilema is what to do. Run it with the light and wait for summer to see if it goes out, get the coolig system flushed as I saw in some of the discussion threads as I don't know if this has been done on this car in the past, or bite the bullet and get it done now. Has anyone had repeat problems after getting it done? Is it worth while? Is there a way for me to "clear the code" and get the light out myself?
  7. #21
    Jonny223 is offline Cadillac Owners Member
    May 2006
    Ontario Canada
    69
    I get the same code when it is really cold a few days in a row...
  8. #22
    tedscts is offline Cadillac Owners Member
    Feb 2008
    34
    Due to poor enginerring of coolant system, the actural parts for thermostat run $65.00 with all gaskets and bits and pieces, its the labor that is killer, dealer has to take off intake manifold to get to thermostat.
    On a Chev V8 its a 20 minute job to change stat.
    I drove my 2003 CTS for 3 years with check engine light on, it will not come on in summer, even when stat is not opening properly, it only happened in cold weather. Had car in florida Oct to April no lite.
    But when I started to get a smell like overheating, I broke down and spent the $640.00, it turned out stat houseing was also broken, or tech broke it and I payed.
    I have noticed an improvement in gas milage, as when stat is not allowing engine to reach proper temp, computor dumps more gas into injectors to try to compensate, whuch of course is not what is wrong.
    just my 2 cents, but as its march now, you could just keep resetting lite, until summer, then it should not come on again until next winter.
  9. #23
    johnlaqua is offline Cadillac Owners Member
    Automobile(s): 2003 CTS
    Nov 2011
    30
    just got my stat and housing replaced by ase tech....stat came with housing from oriellys auto parts for 24 bucks...dex cool coolant to refill after was 20 bucks, labor was 193 bucks....600 bucks lmao sorry to hear
  10. #24
    carrnuttdave is offline Cadillac Owners Connoisseur
    Automobile(s): 2007 CTS
    Aug 2010
    Layton, Utah
    53
    1,572
    nothing like bumping up an old thread!
  11. #25
    odthetruth's Avatar
    odthetruth is offline Moderator
    Automobile(s): 2006 CTS-V
    Feb 2010
    NYC
    4,969
    For real. Debumped.
    [2006 CTS-V]
    Bolt ons and Bolt ins, and Bolt underneaths.
  12. #26
    azfara is offline Cadillac Owners Member
    Automobile(s): CTS
    Oct 2010
    Chicago
    27
    I have 150k on my 03 CTS. I have been fixing the things as I was going along with it. I like this car I have changed the timming belt and all the pullies and wather pump in summer. If I would have known I change the thremostat too. Any way Chicago cold weather and 0128 code come on.
    My friend mechanaic says that it might be just the sensor and not the thermostat. But as I investigate I have to open the intake why not change both.
    For time being I am driving like this. Good luck to me.
  13. #27
    Automobile(s): CTS
    Oct 2010
    Chicago
    27
    Changed both thermostat and temp sensor. Drove for two week. Now temp drop to 10 Degree F and check engine light came back. No coolant leak or any thing. One thing which I notice previously it was used to say check coolant level message, but now it does not show that message just check engine light. Does anyone know where is this coolant level sensor on this car?
  14. #28
    cabletech is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS 3.2L M35 LtPt
    May 2010
    223
    I believe coolant level sensor is in the overflow reservoir.
    Welcome to the persistent P0128 club. At least it'll go away in the summer.
  15. #29
    reddog01 is offline Cadillac Owners Member
    Oct 2011
    9
    Bump, Bump...(keeping this thread alive because we love our CTSs'...dont we???)
    Finally changed the T'stat. This thread is first I've found with sensor mentioned. Wish I'd have found it before I put it all back together. No more P0128, but no hot air from the heat vents. Gotta be a bad sensor. Everything else checks out good. Oh well, live and learn. Shouldn't take as long this time, as I know
    where everything is and where everything goes. On the upside, at least I wont have to replace all the o-rings, vacumm lines, hoses, etc, etc, etc...as I did that
    when doing the T'stat.
  16. #30
    odthetruth's Avatar
    Feb 2010
    NYC
    4,969
    Quote Originally Posted by reddog01 View Post
    Might have to burp the system as you might have air pockets from changing all the lines which could be interfering with the heater core
    [2006 CTS-V]
  17. Remove Advertisements
