Cadillac CTS First Generation Forum - 2003 - 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
 | Cadillac Forums: Any one with SIR-GM1, Need some Info.
01-28-07, 08:50 PM
| | Cadillac Owners Member Cadillac(s): 2005 Cadillac cts | | Join Date: Nov 2005 Location: Queens, New York | | | Any one with SIR-GM1, Need some Info. I just installed the Sirius Sir-gm1 on my 2005 cts with no xm with the harness from radioaandmore.com. I was just wondering if the song title and artist is suppose to be displayed on the DIC. |
01-29-07, 11:03 AM
|  | I am America Cadillac(s): 2004 CTS 3.6L | | Join Date: May 2006 Location: St. Louis, MO | | | Re: Any one with SIR-GM1, Need some Info. It was my understanding that you need XM to buy that conversion unit. You might want to double check that. |
01-29-07, 04:34 PM
| | Cadillac Owners Member Cadillac(s): 2005 Cadillac cts | | Join Date: Nov 2005 Location: Queens, New York | | | Re: Any one with SIR-GM1, Need some Info. Everything works but it only displays the channel name, I thought it was also suppose to show the song and title. |
02-17-07, 04:44 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Any one with SIR-GM1, Need some Info. hay john, how did u go about getting the sirius to work in ur car... seeing im in the same boat as u... i got an 04 cts with no xm, and now i want sirius to come through the factory... thanx in advance...
kevin |
02-17-07, 07:04 PM
| | Cadillac Owners Member Cadillac(s): 2005 Cadillac cts | | Join Date: Nov 2005 Location: Queens, New York | | | Re: Any one with SIR-GM1, Need some Info. I had the radio tech 2 to receive the digital radio, Purchased a special harness from www.radiosandmore.com, and had circuit city install the sir-gm1. Everything thing works great and am enjoying Howard and the music. Also just found out that to show the artist and song info. you use the I clock display configuration. Good luck you should have no problems with it. |
02-17-07, 07:33 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Any one with SIR-GM1, Need some Info. hay john just to make sure, but is this the right harness i need to connect the satellite radio to, seeing that i dont have this, because i do not have xm radio??? http://www.radiosandmore.com/prod_de...RX/CTS%20CABLE
thanx again
kevin |
02-17-07, 07:45 PM
| | Cadillac Owners Member Cadillac(s): 2005 Cadillac cts | | Join Date: Nov 2005 Location: Queens, New York | | | Re: Any one with SIR-GM1, Need some Info. I didn't have xm either, the harness cost $65, I recomend you call them up because the exact product is not listed on their website. |
02-18-07, 11:15 AM
|  | Cadillac Owners Member Cadillac(s): Cadillac CTS | | | | | Re: Any one with SIR-GM1, Need some Info. They raised the price of the part within the last couple days
I bought it for 65$, now it is listed on the site at 78$
The link for it is http://www.radiosandmore.com/prod_de...RX/CTS%20CABLE |
02-18-07, 07:37 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Any one with SIR-GM1, Need some Info. awesome... thanx again chris... o btw can any car dealership with an OBDII scanner do this, or does it have to be a Cadillac dealership, because i work at a saturn dealership.... thanx again
kevin |
02-24-07, 02:53 PM
|  | Cadillac Owners Member Cadillac(s): Cadillac CTS | | | | | Re: Any one with SIR-GM1, Need some Info. Yeah, any GM dealer can do this.
For Me, it cost 65$ total to get the thing tech2'd and installed |
08-18-07, 12:27 AM
| | Cadillac Owners Member Cadillac(s): 2004 CTS 3.6 Black on Black | | | | | Re: Any one with SIR-GM1, Need some Info. Is there any easy way to tell if you have xm capabilities? antenna on the roof, options on the headunit? |
10-02-07, 01:28 AM
| | Cadillac Owners Fanatic Cadillac(s): 04 SRX AWD V8 | | | | | Re: Any one with SIR-GM1, Need some Info. So not to ask a stupid question but the links for the radio cable do not work but the post says I should call to order the harness, kind of conflicting.
My 04 will be here in 2 weeks and I want to have it ready for Sirius, so just to make sure this is the list.
Get SIR-GM1 (sitting here waiting)
Get harness for radiosandmore, if they still offer it
If I can't get the harness, splice into the factory harness and add the pins needed.
Enjoy
I did the NAV, LUX, Sirius install on my Sierra so wiring is no problem
Thanks Matt |
10-02-07, 07:17 AM
|  | Cadillac Owners 10000+ Posts Cadillac(s): Black the Darkside | | Join Date: May 2004 Location: Central Ohio | | | Re: Any one with SIR-GM1, Need some Info. Quote:
Originally Posted by Flyin-Ryan It was my understanding that you need XM to buy that conversion unit. You might want to double check that. | I agree with Ryan. I talked with Sirius and they told me the intent is to convert XM to Sirius. |
10-02-07, 08:38 AM
|  | Cadillac Owners Fanatic Cadillac(s): 2003 CTS | | Join Date: Apr 2006 Location: Arlington VA | | | Re: Any one with SIR-GM1, Need some Info. No, I just added Sirius without having XM before. The harness from radios and more worked great but it isn't cheap. I used the links found here only about a month ago so i would think they still sell it. I remember it being called CTS/SRX harness, at least something with SRX in the title. The total install took me about 15 minutes. I put the SIR GM1 in the glove box and ran the radios and more harness to the back of my nav and it came on instantly. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
