Originally Posted by rochan In order to replace the flickering traingle lights dont you have to take out the whole bumper? Im no mechanic ... do i have to pay someone to do it again? I would if i knew how . Thank you guys for all ur help btw |
I've never felt the need to jack up the car for this job.
You do not need to remove the bumper.
I'm just going to clarify on some things that 1badGMC said to clear things up for you a little more.
1, 2, 3 are the pins you need to remove. Use a flathead screwdriver.
Pull the black thing out of its position & just slip your arm in there (if you need to remove more pushpins, do so.)
From here, you will be working strictly by feel.
There is a fat cap under the headlights, twist it off.
Feel around for the corner/triangle/parking light & squeeze the edges of it to pull it out.
Take the bulb out & replace it with the new LED (remember, LEDs work based on polarity; all that means is that if it doesnt work one way, try taking it out & putting it in the other way). Test to see if it works before you put the cap back on.
done.
