My aftermarket radio install in the CTS - Page 5
Page 5 of 7 FirstFirst 1234567 LastLast
Results 61 to 75 of 92
Like Tree3Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, My aftermarket radio install in the CTS in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I tried that in my 05 cts, i even added the extra relay needed. When i put the fuses in ...
  1. #61
    J W
    J W is offline Cadillac Owners Enthusiast
    Automobile(s): CTS /CTS-V / Escalade EXT / Coupe
    Jun 2009
    605
    Re: Retain DIC with Double Din wiring?
    I tried that in my 05 cts, i even added the extra relay needed. When i put the fuses in the altenate slots the cigarette lighters did not work at all. Could there have been something i did wrong or does it not work for all models.
  2. #62
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,299
    If it didn't work for you, it is hard to say. Are you sure you moved the fuses correctly?
  3. #63
    J W
    Jun 2009
    605
    Yes, i switched the positions to the alternate slot. They just went dead. Could ther be a wire in the dic harness i could use since it still functions properly.
  5. #64
    VaderWS6's Avatar
    VaderWS6 is offline Cadillac Owners Fanatic
    Automobile(s): 05 CTS
    Dec 2012
    179
    Questionaftermarket stereo installation in 2005 CTS
    I'm getting ready to install a new stereo system in my 05 CTS with stock Fisher stereo. Here is a list of everything I have purchased for the car stereo store to install:
    Clarion CX501 Double-DIN
    Scosche Double DIN installation kit
    Metra Axxess ASWC univerisal steering wheel control interface
    4 Kenwood KFC-P509PS 5.25" component speakers
    PAC OS-2C-CTS OnStar Radio replacement interface
    Alpine MRX-M100 1000 watt RMS mono amp
    1 Alpine SWR-12d4 Type-R 12" 4 dual 4 ohm sub
    Vented sub box
    Dynamat trunk insulation kit
    (store will supply wiring)
    Is there anything else I might need to run this system? Will my OnStar system still work with that PAC replacement interface? I don't want to lose OnStar capabilities, and I just want to make sure I have everything needed before I make an appointment for the installation. Any other information would be greatly appreciated, I've heard CTS install are a PITA.
  6. #65
    VaderWS6's Avatar
    Dec 2012
    179
    Bump
  7. #66
    josney's Avatar
    josney is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS
    Dec 2006
    South Carolina
    50
    2,305
    Re: aftermarket stereo installation in 2005 CTS
    looks like you have everything you would need. that adapter is the one you need to keep the chimes and onstar function, its the one i have, although i have never used onstar. the install is not that hard, all the adapters make it actually pretty easy. the install only gets more difficult if you are retaining the DIC.
  8. #67
    VaderWS6's Avatar
    Dec 2012
    179
    Quote Originally Posted by josney
    What's the DIC?
  9. #68
    CadillacAsAlways's Avatar
    CadillacAsAlways is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS 3.2L, Luxury Sport, Diamond White
    Aug 2012
    Pittsburgh, PA
    659
    Quote Originally Posted by VaderWS6
    What's the DIC?
    Driver Information Center. It's what tells you your MPG average, instant mpg, outside temp, timer, oil life, etc etc etc. and it tells you alert messages like low fuel, low coolant, ice possible,
    Personally I like having all that data at my fingertips and wouldn't get rid of it, but it's up to personal preference.
  10. #69
    josney's Avatar
    Dec 2006
    South Carolina
    50
    2,305
    yeah, sorry.....i should have explained that. i have tried it both ways and found that i could not get it to sound good, so i ripped it back out and ditched it. does it take away the "cool factor"?? sure, but i dont miss it.
  11. #70
    VaderWS6's Avatar
    Dec 2012
    179
    Is there a thread on how to retain the DIC? I would prefer to keep it if possible, is there an adaptor I can install to retain it?
  12. #71
    ejn
    ejn is offline Cadillac Owners Member
    Automobile(s): None
    Sep 2012
    15
    Here's a link. You may want to think about buying another radio so that you have some music in the while since the mod takes quite a while.
    http://www.cadillacfaq.com/faq/answe...dic/index.html
  13. #72
    curtc's Avatar
    curtc is online now Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,061
    Insert sales pitch.
    I have a 6 disc Bose head unit with a bad CD mech, perfect for this mod, everything else works perfectly.
    The replacement I bought came with one of those stick on dash kits all over it so I reused my faceplate so you'd need to do the same.
    $75+shipping takes it.
    PM me if interested.
  14. #73
    VaderWS6's Avatar
    Dec 2012
    179
    Got a quote from a trusted stereo shop, for everything installed plus wiring it will be around $350-$400. Does that sound about right for a cts? They can also Dynamat the entire trunk for an additional $100. What do you guys think? They said it will be an all day ordeal, 10am - 6pm
  15. #74
    VaderWS6's Avatar
    Dec 2012
    179
    Bump :P
  16. #75
    josney's Avatar
    Dec 2006
    South Carolina
    50
    2,305
    headunit, speakers and amp install, sounds like a good deal
  17. Remove Advertisements
