My aftermarket radio install in the CTS - Page 3
Page 3 of 7 FirstFirst 1234567 LastLast
Results 31 to 45 of 92
Like Tree3Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, My aftermarket radio install in the CTS in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; are you saying you want to put the DIC info on an aftermarket radio? I doubt that is possible. Or ...
  1. #31
    JimmyH is offline Cadillac Owners 10000+ Posts
    Dec 2006
    42
    37,299
    Re: Retain DIC with Double Din wiring?
    Or do you mean you want to keep the oem lcd display?
    Here is a guy who did something like that recently:
    http://www.cadillacforums.com/forums...wners-who.html
  2. #32
    josney's Avatar
    josney is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS
    Dec 2006
    South Carolina
    50
    2,305
    I think he is wanting to install the aftermarket and retain the DIC. And yes, there have been many threads on it, but never a clear answer that i have seen. I would love to see it described and illustrated better.
  3. #33
    txbest1980's Avatar
    txbest1980 is offline Cadillac Owners Master
    Automobile(s): 2003 CTS "Ebony Maria" 2005 Cadillac STS "Grace"
    Dec 2008
    Wherever Uncle Sam sends me
    36
    6,414
    didnt mjs0202 do a complete write up on this?
  5. #34
    josney's Avatar
    Dec 2006
    South Carolina
    50
    2,305
    Quote Originally Posted by txbest1980 View Post
    You are correct. http://www.cadillacforums.com/forums...-2006-cts.html
    I haven't read it through, maybe it's all in there. I had seen the link on mounting, but never where the wiring was plain and simple for an amateur like me. Thanks for the help txbest1980
  6. #35
    txbest1980's Avatar
    Dec 2008
    36
    6,414
    i know mjs0202 has done this whole thing and saved the DIC, i dont know how is whole write up is though...he is on and off of here these days though
  7. #36
    josney's Avatar
    Dec 2006
    South Carolina
    50
    2,305
    I will take the time to read through the thread at home...big brother is watching.
    thanks again.
  8. #37
    LS6TT's Avatar
    LS6TT is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac CTS
    May 2007
    Fort Worth, Texas
    34
    299
    I searched through that second thread, here is a write up, hopefully this will be the final post. I think cadillacfaq.com should post the write up as well.
    http://www.cadillacforums.com/forums...30-post76.html
  9. #38
    Dec 2006
    42
    37,299
    one caveat:
    you have to be careful splicing into the brown ignition wire on the hvac harness: i have noticed some power adapters drawing power from there can get unreliable current, causing them to cycle on and off.
  10. #39
    LS6TT's Avatar
    May 2007
    Fort Worth, Texas
    34
    299
    Quote Originally Posted by JimmyH View Post
    one caveat:
    suggest another power source?
  11. #40
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,277
    You could always use the brown wire from the hvac to power a relay. While the relay allows voltage to go to the radio from a constant on source. Of course the radio will turn off when the relay turns off with the hvac.
    KOT
  12. #41
    mjs0202 is offline Cadillac Owners Fanatic
    Automobile(s): CTS
    Jan 2009
    303
    Just to update on my Pioneer install. Its been in over six months now and works perfectly. The original noise suppressor I bought died after a couple of weeks, nothing to do with the install just a faulty part. Replaced it with another $10 suppressor and no problems since then.
  13. #42
    Dec 2006
    42
    37,299
    Quote Originally Posted by LS6TT View Post
    I don't have one. The hvac ignition sense is the only one I am aware of that is easily accessible.
    I have my parrot speakerphone kit, as well as my GPS power tapped into that wire, and they work fine. But when I tried to charge my phone off that line it would cycle on and off. Same thing with my laptop. So I had to move them to the RAP from the cigar lighter. (which is fine, I just have to remember not leave them plugged in when the car is off for extended periods of time)
    My only point is that when you tap into that line, you might not get steady current. Some devices need steady current. Others don't.
  14. #43
    Apr 2009
    Ledyard, CT
    38
    9,277
    You know what, there are two other power sources.....
    The power outlets..... Remember fella's the fuses for these power outlets that are under the hood can be switched. From their factory default of always on, to on with ignition. Heck, that might even be just exactly like a RAP. Where the opening of the door turns it off. Best part, is that you could control the front from separate from the rear one.
    I know that ya'll would like "duh" just like I was a minute ago when I thought of those fuses.
    KOT
  15. #44
    LS6TT's Avatar
    May 2007
    Fort Worth, Texas
    34
    299
    it wouldnt be good to assume whatever radio one was to buy wouldnt need the steady current?
    so its best to seak an alternative power source?
    Quote Originally Posted by Kingoftypos View Post
    KOT
    explain how I would change it.
  16. #45
    Apr 2009
    Ledyard, CT
    38
    9,277
    Open the hood, remove the fuse box cover, look for the two fuses. Choose a fuse, or both remove it, move over to the left or right one peg. You'll see what I mean.
    KOT
  17. Remove Advertisements
