CTS-V Differential Swap to CTS
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 42
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, CTS-V Differential Swap to CTS in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Sorry..no answers here but I am interested what would be required. The advantage would be a 3.91 ratio vs the ...
    RobertCTS's Avatar
    RobertCTS is offline Cadillac Owners 10000+ Posts
    Automobile(s): Black the Darkside
    May 2004
    Central Ohio
    22,418
    LightbulbCTS-V Differential Swap to CTS
    Sorry..no answers here but I am interested what would be required. The advantage would be a 3.91 ratio vs the 3.43 we have and beefer gears w/positraction and beefier case.
    Questions:
    1. We will need new axle shafts (2). Will they bolt to our hubs?
    2, The V has a different 2 piece HD drive shaft. What's required?
    3. Will the differential housing have the same mounting locations?
    4. How will this effect my speedo and other related electronics?
    5. Have I forgotten anything?
    If it can be done it would greatly improve my acceleration and give me an LSD which I do not have now. What's you thoughts?
    RobertCTS's Avatar
    May 2004
    Central Ohio
    22,418
    Re: CTS-V Differential Swap to CTS
    It appears no one knows squat. It seems the least evasive of the mods like turbos, SC and ECU mods. It should look OEM factory and not a warranty issue. I changed the gears in my old Corvette and my Road Runner. Both made remarkable difference in acceleration.
    Flyin-Ryan's Avatar
    Flyin-Ryan is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS 3.6L
    May 2006
    St. Louis, MO
    2,493
    Probably need new wheels since you might need to switch to the 6 lug
    RobertCTS's Avatar
    May 2004
    Central Ohio
    22,418
    Quote Originally Posted by Flyin-Ryan View Post
    I don't know. Maybe the axles will hook up to my hubs?
    Will the CTS-V gears transfer to our carrier assmbly?
    Got hook up with Jon, our canadian friend, as he has both the CTS & CTS-V
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    Getting the speedometer to work right may require an external device. I did a little research on what is required to reprogram the ECU so that all the DIC stuff would be correct and that gets so far out of hand so quick it'll make your head spin. It can be done, and if anyone has already had it done it's easy but if you have to foot the bill it's staggeringly expensive.
    Jon's Avatar
    Jon
    Jon is offline Cadillac Owners Master
    Automobile(s): 16 ATS-V, 04 CTS-V, 09 CTS, 07 SRX, 04 CTS
    Feb 2004
    Alberta, Canada
    31
    6,651
    Sorry Robert, but I'm not THAT mechanical lol.
    You could probably ask James, he might be able to help you out. I've asked him a couple questions before and he's always found an answer for me.
    I was thinking about putting a Driverselect shifter into my CTS and get the shifting option, but he said it takes more than that. So yeah, I'm sure he's your best bet at answers.
    Kael's Avatar
    Kael is offline Cadillac Owners Connoisseur
    Automobile(s): The Mighty Kael, 2004 Black CTS, Every Option
    Jul 2005
    IL
    2,430
    i thought the cts-v had 3.73 gears in the rear?
    I need to ask to be sure but I think the gear ratio can be programmed by the dealer with a TechII.
    you wont need new hubs, the axle splines willliine up just fine.
    the stock drive shaft will probably be fine. the V has the HD two part drive shaft becuase the ls6/ls2 is a very torquey engine and might snap a normal drive shaft.
    from what i have heard on the solsitce forums the cases are the same, the internals are different for the Diff's. it should bolt up in the stock location, the width hasnt changed so the stock half shafts should still work.
    this seems to be an upgrade involving the internals of a cts-v diff swapped into the internals of a cts diff.
    (further mounting and size clues: the bmr brace for the V differential also fits the cts differential)
    we'll have to call a dealership to see if they can change the gear ratio using the tech II, although I have heard this can be done.
    aftr the computer gets the correct gear ratio everything else like your speedo and odometer and tranny shifting should be fine.
    -K
    Rey Rey 650's Avatar
    Rey Rey 650 is offline Cadillac Owners Connoisseur
    Automobile(s): CTS
    Mar 2006
    Bay Area, CA
    36
    2,557
    Quote Originally Posted by RobertCTS View Post
    You had a Road Runner? My dad has on in his Garage that he hasnt take out like in a year. Its a cherry red with a vynal top....1968 with a 383..Next time he takes it out I'll snap some pics
    BlueMalibu's Avatar
    BlueMalibu is offline Cadillac Owners Fanatic
    Automobile(s): '07 CTS 3.6 Sport, 6-Speed
    Jan 2004
    Commerce, Mi.
    189
    Possible better idea. Get a 3.73 ring and pinion from a 3.2L manual trans CTS. You should be able to order just these parts. Then have a rear end shop put them in a 3.6L posi CTS unit. Man, I miss the 3.73s my old CTS had.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    Quote Originally Posted by Kael View Post
    -K
    Kael, I remember a Techline article that said that it is not a matter of changing a value in a window. You have to reprogram everything that makes use of the rear end ratio. It said it is more like installing a program patch and it is a huge job to create that patch. If the proper patch exists it's easy, otherwise it's prohibitive.
    Kael's Avatar
    Jul 2005
    IL
    2,430
    crud. well leave it to GM to make it as hard as possible on us.
    I ran a program for a brand new 4l60e for a hot rod build up (friends thing) you just plugged into it with this tool (i think it was a shop version of a techII) and there was a section for programming the ecm to work with the new tranny, there was a line that said "Gear Ratio" you just typed it in and viola, all done.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,241
    The article said there was a library, so to speak , of these patches. If there was a patch for the tire size you wanted or rear end ratio already in existance you were okay but you were SOL if you were breaking new ground until the factory wanted to do it. I can't access Techline anymore so I can't look it up.
    54inches's Avatar
    54inches is offline Cadillac Owners Fanatic
    Automobile(s): 2005 V
    Sep 2007
    Houston, TEXAS
    42
    474
    Any updates?
  16. #14
    Kael's Avatar
    Jul 2005
    IL
    2,430
    wow, this is from a year ago..
    anywho..
    the hptuners software is out so you can change the root gear ratio in the program.
    what koz said was correct to an extent but all of the software does use a single root value for the gear ratio, this is the same thing that is changed for tire size.
    otherwise you would have to use a hardware solution like a modified sprag or a signal interceptor.
    the normal cts would run better with a 3.73 and the V would benefit from the 3.4X (too lazy to lookit up right now) because of a bit less torque off the line.
  17. #15
    Silver Dollar's Avatar
    Silver Dollar is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS-V
    Apr 2006
    Taxus
    4,042
    It doesn't make your car stunt, so no one cares.
  18. Remove Advertisements
