| Re: Volant Users..... For the 3.2L, you should have the airbox, cover, filter, two band clamps for the filter, and MAF/filter adapter. It will also come with about 18" of rubber channel for a gasket on the stock intake hole. If it doesn't come with them, you may need two slightly longer bolts for the MAF to bolt on properly since the 3.2L airbox is countersunk/beveled for the MAF, the Volant is not.
The 3.6L version includes a new intake tube. The 3.2L version of the K&N kit also does, although I'm not sure what it adds. That is simply so you feel like you got your money's worth in spending $250 for an air filter and a bent piece of steel. |
