Cadillac CTS First Generation Forum - 2003 - 2007 Forum for discussions regarding the Sigma-based Cadillac CTS.
 | Cadillac Forums: Cadillac's New Bolt Pattern 5 x 114.3
01-21-06, 09:17 PM
| | Cadillac Owners Connoisseur | | | | | Cadillac's New Bolt Pattern 5 x 114.3 Well, Wheel Warehouse had a manufacturers show today and my wife and I went. Man, it royally sucks when every vendor there had absolutely nothing for our CTS's with our 5x115 bolt pattern. There were some drop-dead gorgeous new wheels, and new great three piece wheels. We headed directly over to the BBS rep and asked about any upcoming 5x115 BBS wheels. Answer: No. Reason: Sticking with the more popular bolt patterns. All the high-end reps said that thought what Cadillac was doing with the Sigma design Cadillacs was great, and would love to make wheels for them, but not in the 5x115 patterns. So here is my idea: When Cadillac either spins-off as a separate entity or after the reorg, Cadillac needs to make a wheel pattern of 5x114.3 at the very minimum, and dump the 5x115 pattern. They had some nice rides there and the biggest kick was an older couple tricking out their new Scion with the latest aftermarket wheels. http://www.wheelwarehouse.com/
01-21-06, 10:58 PM
|  | C.M.A.A. Founder Cadillac(s): Black Raven CTS 2.8 VVT | | Join Date: Dec 2005 Location: Orlando, FL Age: 32 | | | Re: Cadillac's New Bolt Pattern 5 x 114.3 Thats weird. My dad and my brother got 300C's and they have told me that the 300 has a 5x115 bolt pattern. Its not just the CTS with the 5x115 pattern. My brother is all into mopar vehicles and he told me that most Chrystlers are 5x115. |
01-21-06, 11:01 PM
| | Cadillac Owners Connoisseur | | | | | Re: Cadillac's New Bolt Pattern 5 x 114.3 Quote: |
Originally Posted by estrivera Thats weird. My dad and my brother got 300C's and they have told me that the 300 has a 5x115 bolt pattern. | I specially asked for 5x115 and never mentioned the Cadillac unless they asked. It would be nice to confirm whether the 300's are the bolt pattern and what wheel offsets the 300's run with. |
01-21-06, 11:07 PM
|  | C.M.A.A. Founder Cadillac(s): Black Raven CTS 2.8 VVT | | Join Date: Dec 2005 Location: Orlando, FL Age: 32 | | | Re: Cadillac's New Bolt Pattern 5 x 114.3 Quote: |
Originally Posted by SoCadillac I specially asked for 5x115 and never mentioned the Cadillac unless they asked. It would be nice to confirm whether the 300's are the bolt pattern and what wheel offsets the 300's run with. | i'll try to find out from my brother and my dad the offset, but i do know for a fact that the bolt pattern is 5x115 on the 300. They put 22's with 265/30 tires on theirs and they told me the bolt pattern is 5x115. |
01-23-06, 12:52 PM
|  | Cadillac Owners Connoisseur Cadillac(s): The Mighty Kael, 2004 Black CTS, Every Option | | Join Date: Jul 2005 Location: IL | | | Re: Cadillac's New Bolt Pattern 5 x 114.3 114.3 is very common, even with a 115 mm you can still run a 114.3, .7 mm is a very slim difference. , you might need some hubcentric rings at most, usually they bolt right on.
I am willing to bet the 300C does have a 115mm but that they are running 114.3 rims.
supporting evidence: http://www.nconnect.net/~ob/wheels.htm
(well known in the grand prix world) |
01-23-06, 01:33 PM
Originally Posted by Kael 114.3 is very common, even with a 115 mm you can still run a 114.3, .7 mm is a very slim difference. , you might need some hub-centric rings at most, usually they bolt right on.
I am willing to bet the 300C does have a 115mm but that they are running 114.3 rims. | Kael,
Thanks, but no thanks as I have run hub-centric rings (again no thanks) and tolerances are everything when you are talking wheels and parts that use the physics to back them up. When you tighten a lug nut on a wheel it pulls the wheel to center on each of its lug, so the .7 has to go somewhere (some might get lucky and it's equally distributed among the five lugs). Although many people likely run the 114.3 pattern on a 115, it is just not the ticket for me personally, but I appreciate the thought. |
01-23-06, 02:13 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 03 CTS | | Join Date: Jun 2005 Location: Boston | | | Re: Cadillac's New Bolt Pattern 5 x 114.3 Then u pretty much have ur work cut out for u trying to find 5 x 115 bolt pattern aftermarket rims. Most are made to fit a huge variety of cars
Not sure what ur trying to say about hub rings though, yes the .7 as to go somewhere but the hub rings make up the .7 difference so the rims fits properly, that's the whole point. A 5 x 114.3 rim fitted with the proper sized hub rings makes it 5 x 115, so how's tighting the lugs different when rings are used?? Maybe with rubber rings there can be more give at each lug if one lug is tightened more then the other but that's simply solved by torquing each lug to the same ft/lbs or switch to mental rings so there's less potential "give" at the base of the lug. With hub rings mounted the rims shouldnt rest on the lugs, again thats point of the rings, to keep the rim centered and resting on the bore not the lugs.
01-23-06, 02:46 PM
|  | Cadillac Owners Connoisseur | | Join Date: Sep 2005 Location: st clair shores, MI Age: 28 | | | Re: Cadillac's New Bolt Pattern 5 x 114.3 thats pretty sweet how the don't have prices on their webpage...
man, i hate that. |
05-11-09, 08:38 PM
|  | Cadillac Owners Master Cadillac(s): 94 Fleetwood Brougham | | Join Date: Aug 2004 Location: Rockford, IL Age: 42 | | | Re: Cadillac's New Bolt Pattern 5 x 114.3 Back from the dead...
Anyone ever bring a concensus on this? Will ChryCo OEM 5 x 114.3 mm rims work on 5 x 115 mm GM car?
Found a nice set of 300C 18" rims and pondering for my Buick Park Ave.
Thanks!! Quote:
Originally Posted by TripleOught thats pretty sweet how the don't have prices on their webpage...
man, i hate that. | |
05-11-09, 10:37 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Cadillac's New Bolt Pattern 5 x 114.3 Good question.
IF both the Cadillac and Chrysler wheels index on the center bore (which must be exactly the same ID), then the hardened (!) GM lugs might bend that 0.35mm inward to match the Chrysler bolt circle.
On the other hand, if the Chrysler wheels do not index on the center bore, then the first lug nut of the 5 to snug up throws the wheel center off by somewhere near 0.7mm and you wind up with curious wheel tramp at all speeds because the tire is not rotating on center.
Imagine the geometry. Imagine the possible consequences. |
05-11-09, 10:43 PM
|  | Cadillac Owners Master Cadillac(s): 94 Fleetwood Brougham | | Join Date: Aug 2004 Location: Rockford, IL Age: 42 | | | Re: Cadillac's New Bolt Pattern 5 x 114.3 GM has a 70.3mm and ChryCo has a 71.5mm. Seems a lot of websites seem to indicate they do interchange with the larger hub. Quote:
Imagine the geometry. Imagine the possible consequences. | |
05-11-09, 10:58 PM
| | Cadillac Owners Connoisseur Cadillac(s): Sedan de Ville, CTS | | Join Date: Mar 2007 Location: San Antonio, Tx | | | Re: Cadillac's New Bolt Pattern 5 x 114.3 Switching GM and Chrysler wheels is absolutely dangerous. I am serious. Check with Tire Rack, Discount Tire, or any other tire/wheel company.
I just googled for bolt patterns:
Chrysler: 114.3.
GM: 115, 120 (certain newer models, and certain ancient models, btw)
GM: 100 (certain small models)
114.3 and 115 do not interchange.
05-11-09, 11:36 PM
|  | Cadillac Owners Master Cadillac(s): 94 Fleetwood Brougham | | Join Date: Aug 2004 Location: Rockford, IL Age: 42 | | | Re: Cadillac's New Bolt Pattern 5 x 114.3 Honestly the bolt pattern is lesser of a concern to me, the hub is the bigger concern, the wheel MUST sit on the hub, it is the load carrier, the bolts simply hold the wheel to the hub. So the 1.2mm slop between the hub and the wheel is to me the major show stopper, it can be corrected, but I am not cozy with it. I know some who even tow with slop in the hub to wheel and I don't like it. Wheel spacers are #1 culprits in this. |
05-12-09, 04:34 AM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | Join Date: Sep 2008 Age: 42 | | | Re: Cadillac's New Bolt Pattern 5 x 114.3 yeah GM is retarded thinking they can change the world with their 115... for 2008 they gave up thinking they "rule" the rim sizes and went to 120 which is bmw and others so at least is it moving to a more standard rim. MORONS... I emailed them and they go sorry! |
05-12-09, 11:03 PM
| | Cadillac Owners Fanatic Cadillac(s): They should make a new model name for mine but I guess a CTS | | Join Date: Oct 2008 Location: Pennsylvania Age: 19 | | | Re: Cadillac's New Bolt Pattern 5 x 114.3 My wheels fit my car perfect just get asantis they build them for you and your car  | | Cadillac Discussion Tools | | |
Censor is ON | | | |
