Anyone replaced heads before?
Results 1 to 7 of 7
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Anyone replaced heads before? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; So awhile back I posted here about having trouble starting and no compression. Well after months of waiting got the ...
    gannon cts's Avatar
    gannon cts is offline Cadillac Owners Member
    Automobile(s): 03 CTS. 04 SRX
    Dec 2013
    Nebraska
    8
    Replaced valves on 03 cts
    So awhile back I posted here about having trouble starting and no compression. Well after months of waiting got the heads back. So now gonna go and put back together. And my problem before was a result of timing belt slipping. Do I purchased a v6 gm Saab timing belt tool from amazon. How the hell do you use it no manual and can't find one online
    gannon cts's Avatar
    Dec 2013
    Nebraska
    8
    Help. I had replaced valves in the heads of my 03. Well I'm putting it back together and wanna do it right. I know should have taken it in somewhere. Needless to say I'm not mechanically stupid so figured I could save money by doing it myself. Anyway how do I know the cams are positioned correct when reinstalling them. And how do I use this damn Ktc tool I purchased to install the timing belt. Thanks.
    DavidBoren's Avatar
    DavidBoren is offline Cadillac Owners Enthusiast
    Automobile(s): Volant, VMAX, RX catch can, tranny cooler... RIP
    Jul 2012
    Portland, OR
    31
    518
    Re: Anyone replaced heads before?
    I have not replaced the heads on a 3.2 before. But here is a write-up on replacing the timing belt. It might give you an idea of how to get the timing correct. Hope this helps:
    http://www.cadillacforums.com/forums...ming-belt.html
    jran0823's Avatar
    jran0823 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS 1SC Luxury Sport
    Apr 2011
    GB, WI
    30
    1,017
    If you bought the OTC kit there is a booklet to walk you through it. It's not bad, just time consuming
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,223
    Have you looked for a Haynes or Chilton manual? Some folks don't like them, but I've found the one I have for my Subaru is very accurate (compared to the Factory Service Manual, which I also have).
    You can also find the service manuals on DVD on Ebay pretty cheap. I've never purchased one of those disks, but I've seen others say that they're great.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    gannon cts's Avatar
    Dec 2013
    Nebraska
    8
    So cams and valve covers are on. Been using chilton guide. Getting ready to put everything on the front together and put timing belt on. I've noticed on the drivers side outside sprocket there are two timing marks. So do I use the one above the 4.
    Can't figure out how to upload photo
    Quote Originally Posted by DavidBoren
    I have not replaced the heads on a 3.2 before. But here is a write-up on replacing the timing belt. It might give you an idea of how to get the timing correct. Hope this helps: http://www.cadillacforums.com/forums...ming-belt.html
    So thank you for the link your photos helped alot
    gannon cts's Avatar
    Dec 2013
    Nebraska
    8
    So everything is together and it took maybe a day for things to reset. At first I couldn't get above 3000 rpms speedo didn't work. Anyway it's like new except now it idles rough. Any suggestions?
  10. Remove Advertisements
