where did my oil go?
Results 1 to 14 of 14
Like Tree2Likes
  • 2 Post By Oldschool103
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, where did my oil go? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I got an oil change a couple months ago for my 2006 cts, 3.6l. Well assuming Walmart put the correct ...
    pinspade's Avatar
    pinspade is offline Cadillac Owners Fanatic
    Automobile(s): 2006 Cadillac CTS 3.6 liter
    Aug 2012
    perris, ca
    189
    I got an oil change a couple months ago for my 2006 cts, 3.6l. Well assuming Walmart put the correct amount of oil in my car, where could my oil have gone in two months?
    The other day I hear chattering and knocking I check the oil and it's extremely low. It took 5 quarts of oil. I Park on a clean slab of concrete, there are no oil stains or leaks. My MagnaFlow chrome exhaust tips are clean. My fluids are clean. Radiator fluid is clean and oil wasn't milky and my car does not smoke at all.
    So where did 5 quarts of oil go? I haven't checked the plugs yet but I don't think that will prove too much.
    Assuming Walmart filled the oil level. I mean who could forget to put new oil in it?
    Pete(UK)'s Avatar
    Pete(UK) is offline Cadillac Owners Fanatic
    Automobile(s): CTS 2007 Sport Luxury
    Mar 2013
    London, England.
    128
    Re: where did my oil go?
    Was this the oil guy at walmarts that day?
    curtc's Avatar
    curtc is online now Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,061
    Probably into the intake. Look into the PCV mod to hopefully correct it. Might want to look into a catch can and breather cap as well. Unfortunately this is a common problem with the 3.6.
    If you don't look into these mods check your oil very often or you'll be replacing your timing chain. If the chain goes you can bend valves and then your engine is toast.
    pinspade's Avatar
    Aug 2012
    perris, ca
    189
    Quote Originally Posted by curtc View Post
    I've realized this, which is why I posted. My engine completely died on independence day. When I try and start it. Or sounds like someone is taking a hammer to my engine
    Anyone have any idea how much it will cost to have it repaired rebuilt?
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,061
    If it's the chain I've heard $2-3k for the job at a dealer.
    pinspade's Avatar
    Aug 2012
    perris, ca
    189
    Damn that's a lot :/ I might try and trade the car in for the same generation but a V.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Good luck getting much for it if it needs the chains replaced.
    pinspade's Avatar
    Aug 2012
    perris, ca
    189
    I would of course repair it first then trade it as soon as possible.
    Would you guys suggest getting a first Gen V or a second? Other than the fact that it is a visible change.
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,289
    If your car took 5 quarts of oil you burned the bottom end out of it and it's a write-off. Hit the junkyards and see if you can find a decent replacement
    Don't mess with Binky Bear!
    pinspade's Avatar
    Aug 2012
    perris, ca
    189
    Quote Originally Posted by dkozloski View Post
    I'll find out for sure what happens on Wednesday and get a quote.
    Oldschool103 is offline Cadillac Owners Member
    Automobile(s): CTS
    May 2014
    61
    11
    My son's 2005 2.8, just had all the chains, gears, guide's and tensioner's replaced, the whole shmeal. The dealer quoted $3,200 for it all, when he told them that he was a Iraq veteran, they knocked it down to $2,000. Thank you Olsen Cadillac, our dealer of choice, who care's about our veteran's.
    Argent1 and Pete(UK) like this.
    Jim's 06 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2006
    195
    Unless you do all your maintenance work yourself, it's a good idea to check that the things you paid for were correctly done. Any human (including me!) is capable of failing to put the oil in the engine after an oil change, if that's what happened. And it's not just Walmart.
    jcornv15's Avatar
    jcornv15 is offline Cadillac Owners Member
    Automobile(s): 2007 CTS 3.6 Base
    Jul 2013
    San Fernando, Ca
    31
    38
    Could have drained out of the rear main seal. Noted problem with this model. Be sure to check that driveway
  16. #14
    DavidBoren's Avatar
    DavidBoren is offline Cadillac Owners Enthusiast
    Automobile(s): Volant, VMAX, RX catch can, tranny cooler... RIP
    Jul 2012
    Portland, OR
    31
    518
    The 3.6 gets thirsty. One feature our high feature v6's are lacking, is a proper PCV system. These things drink oil like it's nobody's business. If you decide to keep your v6 CTS, get the catch can and breather cap, and drill your PCV tube. There are DIY's and write-ups that can be found with a simple search. I made it a point to check my oil every time I filled my gas tank. It's just something you have to keep an eye on. Regular oil changes... I changed mine every 3k miles. Always kept an extra quart or two of Mobil 1 in my trunk.
    If you do trade for a Vee, get the first generation, hands down. Nothing looks like the first generation CTS(V)... nothing. I think the second gen cars aren't as aggressive looking. And the V2's are heavier (but also stiffer). I don't know, I just really like the first gen CTS.
  17. Remove Advertisements
