CTS 2004 Gear Problems
Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By DopeEffect
  • 1 Post By Tom's Caddy
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, CTS 2004 Gear Problems in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hello everyone, About couple months ago I've noticed that the car was doing a little push when I was switching ...
    se900se is offline Cadillac Owners Member
    Jan 2014
    7
    Hello everyone,
    About couple months ago I've noticed that the car was doing a little push when I was switching a gear (to drive or to reverse). So to make it clear, when I was switching the gear I felt like it was slightly pushed from the back. It was so slight so I didn't think it's something bad (it's 10 years old car).
    Two days ago when I switched to Drive and started moving I felt like the car is on Neutral gear, it started moving (like on neutral) and when I tried to push gas pedal it made a noise but didn't really moved to that speed as I pushed, like it couldn't get to the 1st gear, but when it got it it started driving normally.
    I realised that if I wait for this 'push' the car goes perfectly, but if I try to move right away it feels like it couldn't get a gear. The wait time now is a little bit longer (2-3 seconds).
    What can be the problem? How to fix it?
    Don't really want to go the shop before I consult here as I have no idea about the car insides and any shop can fool me
    Thanks for your help in advance
    Static1120 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS 3.6
    Feb 2014
    20
    352
    Re: CTS 2004 Gear Problems
    I get you, You switch to reverse and you feel the car jerk forward and then switch to drive and it jerks back
    I hate that feeling, I always press the brakes hard but its no use, It feels like it puts stress on the gears every time and I don't think its normal either
    Jan 2014
    7
    Today I stuck on the road, when was making u-turn, it was going forwards like in neutral when I changed the gear to reverse. Then it switched, but then had trouble of getting back to drive. Finally it got the gear and started driving and seemed like it's going ok for now, but I'm still worried to get stuck in the middle of the road.
    What can cause such a problem? Is the the whole gear box that needs to be changed and costs more then the car itself or is it just some small belt that will cost less then $100?
    Please help with the advice
    DopeEffect's Avatar
    DopeEffect is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 3.6L CTS, Hotchkis Sway Bars, FE2
    Jul 2012
    Dallas, TX
    26
    524
    I would take it to a shop/dealership and have them look at it. the more you drive it around in that condition the worse it'll become.
    Tom's Caddy likes this.
    Tom's Caddy's Avatar
    Tom's Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS/ 2008 DTS/ 2008 STS V8 N*/ 2011 CTS4 ALL W/D Pearl
    Jul 2012
    Ontario, Canada
    677
    I would say you are low on tranny fluid, one of the first signs is that you feel in neutral for a few seconds while pulling away in first.
    I would look at you're tran cooler lines going into the rad for any kind of leaking.
    Take it to a dealer not a quick lube and just ask them to check you're tranny fluid. Some good Cadillac dealers do it for free on a CTS knowing a customer really can not check it in their own driveway easily.
    se900se likes this.
  8. Remove Advertisements
