03 cts 3.2l timing belt
Results 1 to 7 of 7
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 03 cts 3.2l timing belt in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hey everyone i have a 03 cts that is misfiring in cylinders #2,4,6 all in one bank. Is there any ...
    garciajoaquin's Avatar
    garciajoaquin is offline Cadillac Owners Member
    Automobile(s): CTS
    Feb 2013
    74
    Hey everyone i have a 03 cts that is misfiring in cylinders #2,4,6 all in one bank. Is there any trick to adjust the timing belt with out buying the tool kit made for these belts? Thanks in advance.
    sandalet's Avatar
    sandalet is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-2003, 3.2 automatic
    Nov 2011
    Chechnya, Grozny-City
    39
    620
    Re: 03 cts 3.2l timing belt
    With this arrangement the camshafts, check the crankshaft label. If it is installed correctly, your problem is not with Belt
    Automobile(s): CTS
    Feb 2013
    74
    The cams line up to the cover marks. Somebody that was helping me with the timing decided to put loctite in the bolt that holds the idler pulley between cams #2,3 and cam #3 moved to the right. Quickly moved it back to the left and lined up the marks. Turned on the car and thats where the misfire started. I did a cylinder pressure test and i got 180-210 psi on all cylinders so i pretty sure i have no bent valves. Checked my spark plugs and all 3 plugs had cracked by the insulator part of the plug. Replaced them with Autolite plugs. Gapped them. Can these brand of spark plugs cause a misfire?
    sandalet's Avatar
    Nov 2011
    39
    620
    I think you should test your ignition module and camshaft sensor
    Automobile(s): CTS
    Feb 2013
    74
    i bought a new ignition coil for those cylinders. How do i test the camshaft sensor?
    swetty is offline Cadillac Owners Member
    Automobile(s): 03 CTS
    Mar 2012
    32
    21
    In having this sane issue. Has a new cook pack but misfire terribly on the same side of the engine. Hooking up to a data logger this weekend but the only codes im pulling are there p0302,4,6. Would love to hear some input as well. I will share my results as well
    Mar 2012
    32
    21
    Anyone?
  10. Remove Advertisements
