The world's first Cadillac CTS with natural gas consuming engine))))
Results 1 to 9 of 9
Like Tree3Likes
  • 1 Post By sandalet
  • 1 Post By Tony427
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, The world's first Cadillac CTS with natural gas consuming engine)))) in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; ---------- Through the installation of of this equipment, I received a marked improvement from 1500 rpm dynamics also silent running ...
    sandalet's Avatar
    sandalet is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-2003, 3.2 automatic
    Nov 2011
    Chechnya, Grozny-City
    39
    620
    Through the installation of of this equipment, I received a marked improvement from 1500 rpm dynamics also silent running idling, and not having absolutely no smell clean exhaust. The octane number of a given fuel-105, the engine is almost impossible to get detonation, I can go 40 km \ h in fifth gear and it will not switch down. I improved my score 0-100km \ h)))
    CTSjones likes this.
    Ikera's Avatar
    Ikera is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac CTS 3.2, 1990 Nissan 240sx Turbocharged
    Apr 2013
    Vancouver, BC
    31
    383
    Re: The world's first Cadillac CTS with natural gas consuming engine))))
    wow looks interesting, is there a Natural Gas Conversion kit made or did you make everything yourself.
    Tlorenzen is offline Cadillac Owners Connoisseur
    Automobile(s): 03 CTS (Dead), 06 3.6 CTS(Sold), 07 CTS-V
    Jan 2011
    Melbourne, FL
    1,504
    Interesting. Do tell more.
    ztollon's Avatar
    ztollon is offline Cadillac Owners Enthusiast
    Aug 2012
    629
    What's the power like?
    sandalet's Avatar
    Nov 2011
    39
    620
    I will try to make a video and show
    Tony427 is offline Cadillac Owners Member
    Automobile(s): CTS 3.6 Luxury Sports
    Jul 2014
    Walsall UK
    23
    Just digging up this slightly old thread as I'm just finishing off my LPG install and require a bit of information.
    I need to splice in two wires (one each bank of cylinders) from the gas ECU into the CTS Lambda sensor wiring for a piggy back signal to fine tune the gas ECU.
    Unfortunately each Lambda has 6 wires and its very difficult to find out which of the six wires I need to splice into. The kit is a Stag 300 6 ISA from Poland and emails to Stag have elicited zero response.
    Sandalet did you have to splice into the Lambda sensors and if so which wires?
    Anyone else know which colour wires I should splice into?
    Cheers,
    Tony
    Jul 2014
    Walsall UK
    23
    Hi Guys,
    A big thank you to Luke Butler from Lindsay Cadillac who went the extra mile to send me some wiring diagrams that enabled me to finish my LPG install. I then got the Mrs to drive me about for 45 minutes whilst I tuned the LPG computer through a link up with the laptop. Its now almost perfect ( a bit rich at high revs but what the heck) but I can always tune it anytime..
    Suffice to say I'm so pleased to be able to buy fuel at 60 pence per litre instead of £1.33 per litre. Given that in two weeks time we are off on a 3000 mile holiday I will actually almost get payback on the costs of the install just from the savings on the holiday fuel.
    As the Caddy is actually my Mrs commuter car she will see a saving of over £150 per month on her fuel bill alone. Plus I can add a good 50% to my oil change intervals as the LPGis so clean there's no hydrocarbons to dirty and contaminate the oil.
    I'm a very happy bunny tonight.
    Cheers,
    Tony
    jgclark likes this.
    sandalet's Avatar
    Nov 2011
    39
    620
    Quote Originally Posted by Tony427 View Post
    Cheers,
    Tony
    I'm sorry, just now saw your question. On my gas equipment no connections to the injectors. All data are taken from the socket OBD, this connector is docked special socket on the computer LPG.
    By the way, I strongly suggest you to use the equipment BRC. You will forget about the correction of the fuel mixture and high fuel consumption.
    Jul 2014
    Walsall UK
    23
    Quote Originally Posted by sandalet View Post
    Thanks for that, I've bought a Stag system as it was cheap and seemed to be able to do the job, and to be honest it has.
    I spent a few more miles collecting getting the high revs/ high power petrol map, it appears that the Mr's idea of full throttle is significantly below what I consider full throttle, and now the LPG map is a mirror of the petriol mapping throughout the load and rev range.
    The only downside is a EML code which tells me that the fuel tank pressure sensor isnt seeing a big enough vacuum, so its out of range. Yep, when no fuel is getting sucked out of the tank there will be significantly less vacuum in the tank. I may rig up a restricted tank purging line into the inlet manifold so that there is some vacuum in the fuel tank but then again perhaps I'll just ignore the light.
    I asked the other half if the EML light annoyed her and her comment was "What light?"
    Re BRC I trade the odd car and I sold a Nissan Xtrail last week with a BRC system on it and it looked a very good system, very well thought out. Its not available for home tinkerers like me however in the UK and getting help and spare parts is difficult. Its also a bit pricey to get a kit installed by a professional, it would have cost me what I paid for the car!!
    LPG prices over here seem to be falling and LPg can now be bought at 50 pence per litre compared to £1.29 per litre for unleaded. thats £5.86 a UK gallon to you lucky colonials .........or $9.72.......
    Cheers,
    Tony
  12. Remove Advertisements
