Results 1 to 3 of 3
Thread: Rear Airbag Panel
    mattfranz is offline Cadillac Owners Fanatic
    Automobile(s): CTS
    Jun 2014
    256
    Rear Airbag Panel
    I recently bought a 2003 Cadillac CTS. It has a few issues which I intend on fixing myself as I fixed the majority of mechanical and non-mechanical problems with my old car. The first problem I want to tackle is the piece of trim in the back of the car in the interior covering the side airbag is hanging down. Where can I buy a new one? I don't know exactly what to call it so finding it anywhere online hasn't exactly been easy.
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,463
    Re: Rear Airbag Panel
    Folks refer to them as "sail panels" (since that's what the Factory Service Manual calls them), and there's a quick fix that you can do (rather than buying new ones). If you use the google search function and look for "sail panel fix" you'll find a number of threads, mostly in the 2004-2007 V forums. Basically, it's just a matter of using a washer to fix where the mounting hole cracks and lets the mounting screw pull through.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    Automobile(s): CTS
    Jun 2014
    256
    Alright thank you!
  • You may not post replies
