What the heck is happening?
Results 1 to 11 of 11
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, What the heck is happening? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hey all, My issue started mid winter, it was suuuuper cold, and as i was on the on ramp leaving ...
    foland is offline Cadillac Owners Member
    Apr 2013
    26
    Hey all,
    My issue started mid winter, it was suuuuper cold, and as i was on the on ramp leaving for work their was a slight stutter almost like the tires were slipping slightly then the check engine light started flashing, it stopped and was fine seconds after(i figured my car didn't have time to heat up). The next time it happened was a month or more later at the same spot on the on ramp while it was raining. Then the 3rd time it happened it was also on the on ramp but regular conditions.
    Today is the 4th time is has happened on the on ramp, but this time it happened multiple times during my drive as well(an hour+ drive), and on my way home. It SEEMED as if it was happening more often when i was accelerating quickly but i can't be certain.
    Any Idea what this could be?
    EDIT: I have a 2006 3.6l cts with about 110,00 miles
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,033
    Re: What the heck is happening?
    A flashing CEL is signaling a severe misfire being detected. Have you checked your oil level at all recently? I would see if you can take it somewhere that can scan the codes. There just might be a history code stored that will tell you which cylinder was misfiring, that will help narrow down the culprit. Could be a coil, spark plug, fuel injector, and worst case is a stretched timing chain (not good!).
    kylebooth is offline Cadillac Owners Member
    Automobile(s): 2007 CTS
    Aug 2011
    Saskatchewan, Canada
    26
    87
    Quote Originally Posted by curtc View Post
    Yes, Same thing happened to me about a month ago, swapped out spark plugs, cleared the codes and it works fine now. It could be a coil pack as well.
    pearl03's Avatar
    pearl03 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 CTS
    Jul 2011
    Cobourg Ont. Canada
    53
    147
    I'd just stay away from that off ramp......lol... sometimes humour helps, not with the car but with the situation. Take it to get the codes read, and post them here, maybe someone can help you out.
    voodoochikin04 is offline Banned
    Automobile(s): 2003 cts, 2004 Cts-v
    Nov 2012
    Norfolk, NE (eastern Nebraska)
    31
    316
    lmao.. that ramp doesn't seem to be a good place.. my logic tells me that when your putting a good load on the engine such as going up the ramp... its causing a misfire. which then would lead me to believe you should read codes and change plugs. Coils could be cracking due to age and need replaced.
    if it was a stretched timingchain/ worn guides.. it would be running rough even at idle and all through the rpm range.
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,033
    Quote Originally Posted by voodoochikin04 View Post
    Not true, if it's just a little stretched it may only exhibit symptoms under heavy load.
    Nov 2012
    31
    316
    I don't buy that. theres always a load on the chain whenever the car is running.. whether its stretched a little or a lot... its always gonna be pulling against the chain and running in an off timed situation.
    but I may be wrong.
    curtc's Avatar
    Jul 2005
    Oakdale, MN
    31
    6,033
    When under a light load the chain may stay on time just fine, when under heavy load it can skip if it's stretched.
    Think of a bike with a loose chain, peddle slow and you might be OK, start peddling faster and it's probably gonna start jumping.
    Nov 2012
    31
    316
    I've dealt with stretched timing chain and severely worn guides before on the 3.6 in cts.. a stretched chain or worn guides doesn't cause intermittent issues. once an issue/ always an issue unless resolved. make sure to let us know what you find OP..
    Aurora5000's Avatar
    Aurora5000 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 STS V8 Blackberry,2004 CTS 3.6 Loaded, 2016 SRX LOADED
    Oct 2003
    Tornado Alley Oklahoma City
    482
    Unplug your battery both terminals for an hour.
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,224
    Quote Originally Posted by Aurora5000 View Post
    Why?
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  14. Remove Advertisements
