My driver's side windows quit (both frt & rear) windows do not move --- when I use the driver's door switches I hear a click or relay click but windows don't move.
The fuses under the rear seat is good, is there any other fuses?
remove passenger front seat (weighs a million pounds). pull up the rear passenger carpet. there are 5 fat red (10gauge or so) wires that meet in the middle of the rear passenger floor pan and are joined by a copper crimp connector. these are the power wires to each door. Ive repeated seen this connection become loose of corroded and cause one, two, three or all four door windows to quit. many times this has been the issue. Just need to remove corrosion and recrimp together.
Just a UN-related question; did you have a sunroof drain tube leak because I still have water in the right-rear floor after a down pour that I haven't been able to put my finger on yet?
the car that we dealt with personally was a salvage car and we had guessed it sat with the windows down.. but other have had sunroof leaks and such. if youre getting water back there.. im very confident your problem is corrosion on that crimp..
Your opinion:
All of a sudden, (the starter is acting up), when trying to start, it sounds like a low battery condition but battery is a new high amp and had it checked to be good.
As I turn the switch to start, I hear that the solenoid engaged the Bendix but nothing happens !!
Do you think it might be these wiring again or the starter ??
I came up before the ASE but built a few hot-rods ... so I'm going to address this wiring issue !!
I disconnected battery and the passenger seat 2 wiring connecter's and with help of a friend removed the (Da**) heavy seat and will start removing the door seals and carpet to get access to this wiring connectors.
I also noticed the stuff in the dash glove compartment was wet, I can only guess that a water leak was coming from the cabin filter area.
Will post my on-going experiences.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
