2007 cts 3.6 help!!!!!
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 38
Like Tree7Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 2007 cts 3.6 help!!!!! in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; so i was driving to my gf house 300 miles away adn my car started acting weird (when i started ...
    Nickmalone81 is offline Cadillac Owners Member
    Automobile(s): 2007 cadillac cts
    Jun 2013
    35
    34
    so i was driving to my gf house 300 miles away adn my car started acting weird (when i started off and gave it gas it was go bu tthen the front started nocking a little but then went away adn then nothing more until i slowed and gave it more gas to speed up) so it was not a bad issue really and i tryied to clean teh throttle a little with some spray on degunker and it got a little better but on my way home this am ( 300 miles back) it got worse liek the car was wanting to die and it was a little jumpy i really thought it was goign to die adn have to be towed. the car has liek 91000 miles. it had no check engine light til this am but now its one and staying on. what coudl this be in your opinons ??? cat ??? fuel filter ?? what ?? i plan to take it to get the codes read tonight but i am worried until then. i have to travel wed night and am not sure what he issue is and if its cat then thats liek big money and no one has teh part in stock ... lplease help !!!!!!
    Tom's Caddy's Avatar
    Tom's Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS/ 2008 DTS/ 2008 STS V8 N*/ 2011 CTS4 ALL W/D Pearl
    Jul 2012
    Ontario, Canada
    681
    Re: 2007 cts 3.6 help!!!!!
    The only way it would be the cat is if one was really plugged and I mean really plugged I doubt that. The knocking sounds like a miss. That could fry the cat if you keep driving it like that.
    You have to get the code or codes and post them ASAP so the board can help you. First I would check you're oil level right now if you can. Do you have any timing chain rattle at the very front off the engine by the drive belts?
    Jun 2013
    35
    34
    The sound is only in the very beginning not at all during any other part of the drive ... I replaced all the plugs 2 months ago ... Oil is fine ... When I crank the car there is no noise at all just smooth idle basically ... Issue is only when I am driving and when giving it gas or slowing down ... I felt like it was a fuel filter clogged up at first but when it got worse so quick ( keeping in mind I drive 300 miles last night ) I was worried it was the cat and trust me I so not want to mess with the cat .. I called every exhaust place and everyone is saying 800 to 1700 and double if it's both cats ( which I thought there was only one) ---------- I do drive a lot thou ... I drive every weekend to see my girl 300 miles down and 300 back se times 2 times a week ...
    CTSM is offline Cadillac Owners Enthusiast
    Automobile(s): CTS 08' 3.6 DI Performance | 07' Lux 3.6 Volant-Borla-Vsways
    Mar 2012
    943
    OP stop trying to fix your car before knowing what the deal is. Go to any auto parts store and get the codes read for free. Knowing is half the battle, not knowing is stabbing in the wide open dark. Once you get the codes then definitely somone here will have a clue what's going with your car. It could be anything right now so no point in guessing trust me.
    Jun 2013
    35
    34
    I understand that I'm just stuck at work trying to narrow it down a little bit .. I have a baby on the way and don't need a 1700 dollar cat issue but if it is that I wanna prepare myself ... I plan to hit autozone ASAP tonight at 530 and figure out more then I'll post on here .. Also I wanted to check prices and part availability so I wanted to get options on what it might be so I could check into that ... I'm on a crazy schedule this week and needed to make sure parts are available
    Jul 2012
    Ontario, Canada
    681
    Quote Originally Posted by Nickmalone81 View Post
    Please have the codes read ASAP before you order or spend a penny on anything.
    If it is a cat you will get a P0420 or P0430 code.
    Jun 2013
    35
    34
    Thank you for that info I am goijg tonight to get them read
    Jun 2013
    35
    34
    P300
    P301-p306
    I just changed all the plugs 2 months ago
    Jun 2013
    35
    34
    Any suggestions
    Jun 2013
    35
    34
    holsgo is offline Cadillac Owners Fanatic
    Automobile(s): 2007 cts
    Apr 2011
    143
    I'm pretty sure you've posted the wrong codes, but I believe you mean P0300 etc. Those are cylinder misfire codes. P0301 means cylinder 1 and P0306 means cylinder 6. What I'm thinking is "what changed". You did the plugs and that leaves either an incorrect gap or you didn't put the coil back on properly. The reason I think its plugs and coils is that it seems to affect all cylinders. Just a guess here.
    Last time I had to fix this it was as simple as a regap of the plugs and I replaced all coils. Done. Replaced the fuel filter to clear a lean condition code and she purred after that.
    Doubt its the cat so stop trying to chase that tail until you address these other issues.
    Jun 2013
    35
    34
    I changed the plugs 2 months Ago and no issue why would it happen all of a sudden ... It's at the shop now so I guess it's up to them ... I also had the oil changed about 1 week ago Nd I keep reading that the oil level can affect this ???
    Jun 2013
    35
    34
    Ok since no one was replying here I started a new thread which got blocked or something....
    2007 cadillac cts 3.6l
    91xxx miles
    New plugs 2 months ago
    Started acting odd when I hit the gas after a few seconds and then normal ... Then if I let of the gas and then back on little shutter little noise from front of car but stopped after a few seconds ... Drove 300 miles home and 100 miles in it got bad and continued to get worse until I got it to Midas ... They jut called and said come get the car we can't help you .. Take it to the dealer ..
    Codes
    P0300
    P0301
    P0302
    P0303
    P0204
    P0305
    P0306
    P0101
    Love data
    Bad erratic mass air flow reading
    Noise from VVT system
    What is up !!?!?!?!?!! Can anyone give me any ideas ???? What could've wrong ??? And all at once !!!!! Ran like a top then boom this mess !!!
  16. #14
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,214
    Start with the P0100 code, which is a MAF sensor issue. Remove the MAF and clean it with specially made products for MAF... http://www.autozone.com/autozone/acc...ier=36011_0_0_
    The instructions are basic. Remove the sensor. Use the spray. Do NOT physically touch the sensor's electronics. Let it air dry for 5 minutes before installing back into the air duct.
    Clear the codes and see what happens.
    KOT
  17. #15
    Jul 2012
    Ontario, Canada
    681
    You said in post #3 the oil is fine. Did you check the oil like I asked you to do or, are you just going by the fact you had it just changed. These engines have been known to go through engine oil very quickly.
    If the oil was low on that 300 mile trip it could have everything to do with what is happening.
    I hate to think the worse but almost sounds like a chain JUMP.
    Have someone else start the car and you listen right at the front belts for a RATTLE sound.
    But please don't spend anymore money at midas or anywhere else. Take it to a Cadillac dealer and for $59 diagnostic they should be able to tell you if it is just FUEL INJECTORS, COILS or the dreaded TIMING CHAIN.
  18. Remove Advertisements
