2006 3.8 oil leak from filter cap
Results 1 to 15 of 15
Like Tree3Likes
  • 2 Post By arw1510
  • 1 Post By arw1510
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 2006 3.8 oil leak from filter cap in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; first post, great site. After changing oil, it now leaks from the threaded oil filter cap. Torque is correct. The ...
    kakrjh95 is offline Cadillac Owners Member
    Automobile(s): 2006 cts
    Oct 2010
    first post, great site. After changing oil, it now leaks from the threaded oil filter cap. Torque is correct. The o-ring above the threads looks fine, but should that be replaced after every oil change (it was not included with the new filter)? The store only had an STP filter. Or could the issue be that oil was perhaps not fully drained so it was over filled, causing high pressure/leakage? Any advice is greatly appreciated.
    arogers260's Avatar
    arogers260 is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS Luxury/Sport package
    Mar 2012
    Indiana
    722
    Re: 2006 3.8 oil leak from filter cap
    I replace the o ring everytime and it is typically included with the filters I purchase. There shoulf be a small oring for the bolt and a larger oring for the cap fot my 03
    I also replace the oil pan bolt just about every oil change as well with a new gasket on that. Theyre so cheap I don't see a reason not to.
    CTS_JOEY is offline Cadillac Owners Member
    Automobile(s): 2005 CTS
    Mar 2014
    29
    6
    O-Ring should definitely be replaced with every oil change. I worked at a Walmart as an oil changer and I've seen the effects of not changing the o-ring first hand on a Mercedes that came in with oil all over the place . We popped the hood and found it leaking around the filter housing. Changed the oil, filter and o-ring and it stopped leaking.
    The heat and force on the o-ring flattens them out and they don't fill the gap like they are meant to once they are removed. Take the old one out and take a look. I would be willing to bet it looks more like a triangle ring.
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    37
    9,160
    Good luck in finding an o-ring with the filters.
    I have two cars that require the same style filter. In the last 6 to 8 years owning these cars and having 20 plus oil changes. Only ONE filter came with the o-ring.
    KOT
    HawkzillaCTS is offline Cadillac Owners Member
    Automobile(s): 2006 CTS 3.6L
    Oct 2013
    Iowa
    60
    Get an ACDelco PF2129 filter from Amazon - Comes with a ring and is a great filter and at $7 you can order a few at once and always have one on hand.
    arogers260's Avatar
    Mar 2012
    Indiana
    722
    The puralator from advanace auto parts has both o rings with new filters.
    Tom's Caddy's Avatar
    Tom's Caddy is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 CTS/ 2008 DTS/ 2008 STS V8 N*/ 2011 CTS4 ALL W/D Pearl
    Jul 2012
    Ontario, Canada
    680
    Quote Originally Posted by Kingoftypos View Post
    KOT
    Napa Gold always comes with a red o-ring.
    arw1510 is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS 3.6, 2004 SRX 4.6 AWD, 2012 CTS 3.6 DI AWD
    Oct 2008
    1,229
    I'd be more concerned as to how you have a 3.8l in the car
    RippyPartsDept and Kad4Life like this.
    Jul 2012
    Ontario, Canada
    680
    Quote Originally Posted by arw1510 View Post
    I have a 3.8 Supercharged in my GTP.
    Oct 2008
    1,229
    Yeah. So what? Caddy never offered one in the cts
    Jul 2012
    Ontario, Canada
    680
    I was agreeing with you ( Pontiac and Buick ENGINE ).
    I was trying to be funny like I thought you were about his type O but you must think he was serious about the 3.8.
    Oct 2008
    1,229
    It was probably a long day. Is it Friday yet?
    Tom's Caddy likes this.
    Oct 2010
    thanks guys. I ordered the o-ring from amazon, and that stopped the leak.
  16. #14
    Kad4Life is offline Cadillac Owners Connoisseur
    Automobile(s): '07 CTS 3.6 FE5 Blk/Blk 'Nadine'
    Jun 2010
    Northeast
    70
    1,064
    Nowhere near ..
  17. #15
    Apr 2009
    Ledyard, CT
    37
    9,160
    Quote Originally Posted by Kad4Life
    Nowhere near ..
    Yes, but two Fridays has past between the two posts. :-)
    KOT
  18. Remove Advertisements
