Codes
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By rick001
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Codes in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I just got back from autozone and they did a dio check on the car and came back with these ...
    bmeans12's Avatar
    bmeans12 is offline Cadillac Owners Member
    Automobile(s): 2003 CTS
    Feb 2014
    Canton, Oh
    43
    Codes
    I just got back from autozone and they did a dio check on the car and came back with these codes
    P1700
    P1779
    P1795
    I've tried looking them up on google but can't really find true answers. Can you help with these issues?
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,033
    Re: Codes
    P1700 - "Malfunction Indicator Lamp requested by trans control module"
    P1779 - "Engine Torque Delivered to TCM Signal"
    P1795 - "CAN Bus - Throttle Body Position"
    So what's the car doing exactly?
    rick001 is offline Cadillac Owners Member
    Automobile(s): 2003 Cadillac CTS Luxury Sport
    Feb 2014
    64
    20
    Re: Codes
    If you have a 2003 CTS you can check the codes yourself. It has a built in OBDII reader in the radio. Turn the ignition on and hold in F1 and F6 on the presets, when it comes up check the ECM codes. At the top of this forum check the DIY'S and it tells the codes.
    curtc likes this.
    bmeans12's Avatar
    Feb 2014
    Canton, Oh
    43
    When the car threw these codes it was shifting hard and downshifting hard. Power seemed light too, meaning not much acceleration power
    locoman687 is offline Cadillac Owners Member
    Apr 2013
    Re: Codes
    I just had the same codes, clean your throttle body with carb spray, apply dielectric grease to the electrical connector and perform the throttle pedal relearn found on cadillacfaq.
  8. Remove Advertisements
