#5 Engine misfire with horrible shaking. Please help!!!
Results 1 to 7 of 7
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, #5 Engine misfire with horrible shaking. Please help!!! in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I have a cylinder #5 misfire. I have already changed all 6 plugs, the coil on cylinder #5 that is ...
    Melb is offline Cadillac Owners Member
    Automobile(s): 2006 CTS
    Apr 2014
    Michigan
    7
    I have a cylinder #5 misfire. I have already changed all 6 plugs, the coil on cylinder #5 that is misfiring, and the injector. I know that is the cylinder by running a scanner and it repeatedly come back with the same code after being cleared. Also while accelerating the engine light is solid when settling into a speed say 60mph the light starts blinking. The idle is rough half the time and the car shakes horribly! Any ideas???
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,211
    Re: #5 Engine misfire with horrible shaking. Please help!!!
    Swap the coil pack with cylinder 5 and 6. If the problem follows the coil pack, then change that out. If not then it maybe something else, just report back.
    Swapping coil packs of cylinders 5 and 6 will only take a few minutes as you don't need to remove the upper intake.
    KOT
    Apr 2014
    Michigan
    7
    I already did that before I changed the coil. The problem didn't follow but I replaced it anyways just to be sure.
    ztollon's Avatar
    ztollon is offline Cadillac Owners Enthusiast
    Aug 2012
    629
    Any vacuum leaks/intake manifold gasket failure?
    superman21_00's Avatar
    superman21_00 is offline Cadillac Owners Member
    Automobile(s): 04 cts
    Apr 2014
    Texas
    I have the same problem with my 04 cts but with #2 cylinder I have changed the coil, spark plugs, fuel injector and have tested if it is grounded. I finally gave in and took it to the dealership and they are telling me that the ECM is bad so that is 900.00 going to that. I hope it fixes the problem.
    Oh ya my car has 107,000 miles and the dealership told me that they tried to get into the computer but that the computer would not let them in the program.
    Apr 2014
    Michigan
    7
    I dont believe there are any leaks we replaced a couple seals around the vacuum hoses.
    ieve i jave any leaks. I already replaced the seals on the vacuum hoses.
    Please let me know if the emc fixes the problem! I am planning on taking mine in monday so ill see what they say.
    Apr 2014
    Texas
    Will do, mine will be ready on Monday afternoon so will post it up if it fixed the problem.
  10. Remove Advertisements
