Gas tank sloshing sound and hard start
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 7 of 7
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Gas tank sloshing sound and hard start in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hello everyone, I have a problem no one seems to understand!!! I have a Cadillac 2004 CTS 3.6L V6 and ...
    JakariCaddy is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac CTS 3.6L V6
    Apr 2014
    3
    Hello everyone,
    I have a problem no one seems to understand!!! I have a Cadillac 2004 CTS 3.6L V6 and it makes some weird sucking/sloshing/"washing-machine-like" noises coming from the
    rear passenger area (back by the gas tank) and it can be heard in side the car. I know at one point, I took the gas cap off while it was making this noise and the car acted
    as if it wanted to shut off. I dont know if anybody has ever heard of this or seen this before, but Im starting to feel as if I am the only one that has ever had this problem. Noone seems to know..... Also with this problem, when I put gas in the car, it acts as if it doesnt want to start. I will put in the gas and try to crank it up, but it will cut right
    back off, then I will try again and it will cut back off. I will have to sit for a couple-few minutes and try again. After sitting for a couple to a few minutes it will finally start butI cant go anywhere- I try to give it gas but it will not move; it will sit there as if in a low power state and then after about 3 minutes I can give it gas and it will go. There is
    still that weird sucking/sloshing/"washing-machine-like" noise though. What in the heck is going on??!! Can anybody help- am I the only one with this problem???!!!
    Also sometimes when the car is sitting idle, the RPM will start off at about 1.5 then decrease like it is about to shut off.
    HELP IF YOU CAN!!!!!!!!!!!!
    Also I would like to add, I don't get very good gas mileage.
    arw1510 is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS 3.6, 2004 SRX 4.6 AWD, 2012 CTS 3.6 DI AWD
    Oct 2008
    899
    Look on here for the evap purge solenoid issues. Yours sounds similar, but not to the full extent.
    krusty_tc is offline Cadillac Owners Member
    Automobile(s): 2003 CTS Luxury Sport
    Apr 2013
    49
    50
    Re: Gas tank sloshing sound and hard start
    I've read about people having water inside the bottom of their doors. Check the drains at the bottom of the doors to see if any water is sitting in them.
  5. #4
    Eddiebrock90 is offline Cadillac Owners Member
    Automobile(s): 04 cadillac CTS
    Sep 2012
    5
    That's how I would describe the noise and problem adding gas when my purge valve went bad
  6. #5
    Apr 2014
    3
    Thank you guys so much! I will definitely replace that purge solenoid. It is an easy fix. I am praying that is all it is!!!
    I wouldn't need to be concerned abut the fuel pump do I?
  7. #6
    Kingdady is offline Cadillac Owners Member
    Automobile(s): 2004 cadillac cts
    Apr 2014
    6
    i got the same issue right now .. anyone?
  8. #7
    CTSUK's Avatar
    CTSUK is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Cadillac CTS 3.6 Sport Luxury
    May 2012
    United Kingdom
    32
    722
    try replacing the evap purge solenoid, they are not to expensive and quick to change out.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
