3.2L thermostat thread question
Results 1 to 8 of 8
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 3.2L thermostat thread question in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hello, In the picture attached would you be able to confirm if the circle bolt hole is supposed to be ...
    chrisc543 is offline Cadillac Owners Member
    Mar 2014
    6
    Hello,
    In the picture attached would you be able to confirm if the circle bolt hole is supposed to be open through to the antifreeze passage? I can push straight through it and out the other side. To me it seems like it is going to leak.
    Any input would be appreciated.
    Thanks,
    Chris
    Mar 2014
    6
    Re: 3.2L thermostat thread question
    Bump. Does anyone have any ideas?
    jeff0101 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac cts luxury sport, with slotted rotors
    Feb 2010
    Fredericksburg, Virginia, Unit
    24
    203
    Dont remember seeing that when I did my t-stat
    Also I think you will be ok as long as threads are good.
    Mar 2014
    6
    Thanks for the reply. the threads seem ok. I also got new bolts as they look to have some type of coating on them. I just dont want to get all back together and then it leaks from there. was debating using some loctite on the threads to hopefully seal it more.
    Feb 2010
    24
    203
    Yea that should do it. I was more worried about the metal pipe not sealing. But I replaced it before winter and no leaks yet
    Mar 2014
    6
    well got it all back together last night and it looks like the thermostat is leaking
    Feb 2010
    24
    203
    That sucks. Can you tell if its coming from that thread hole?
    sjdiez50 is offline Cadillac Owners Member
    Automobile(s): 2003 CTS
    Sep 2011
    56
    Hello,
    I recently replaced the thermostat on my euro-spec cts (started acting up short of 100.000 Kms).
    I can confirm that the screws which fasten the thermostat housing to the engine block, go all the way through the engine block into the water jacket. As a matter of fact, the shop manual, in page 6-273, says that the screws have to be coated with sealant GM P/N 12346004 (Canadian P/N 10953480) before assembly. However no word of it in the section dedicated to thermostat replacement. Not having access to those sealants, I used LOCTITE 572 anaerobic thread sealant on the threads, and also around the screw holes at the top and bottom of the housing (taking care not to stain the rubber seal with it). So far no leaks.
  11. Remove Advertisements
