2007 CTS misfire at idle, no codes
Results 1 to 11 of 11
Like Tree6Likes
  • 1 Post By Kingoftypos
  • 3 Post By Kingoftypos
  • 1 Post By softail123
  • 1 Post By the cadillac man
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 2007 CTS misfire at idle, no codes in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; ...
    softail123 is offline Cadillac Owners Member
    Automobile(s): (2) 2007 CTS Luxury Sport Package
    Jul 2010
    Clark, NJ
    4
    I have a 2007 CTS 3.6L with 104K miles. Recently I noticed what seems like a misfire at idle. When it misfires, the car shakes, the first time it happened I thought someone tapped my car. It only happens at idle and it is not throwing any codes. Otherwise it runs fine. At first it was only occasionally but it seems to be happening more often. Without any codes to go by, I don’t even know where to start. Has anyone experienced anything like this. The plugs were changed about 10K miles ago.
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    37
    9,158
    You'll need to take it some where that has a scanner that can to LIVE scanning. It'll need to be on the setting while the engine is running and on the spark plug/coil pack/cylinder area. So that it can see the misfire. Let it run for a few minutes and replace the coil pack(s) on the cylinder(s) that has several misfires.
    KOT
    epchavez likes this.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,674
    Re: 2007 CTS misfire at idle, no codes
    Quote Originally Posted by softail123 View Post
    Hi softail123,
    I am sorry you are experiencing misfire like issues while your CTS is in idle. If you would like me to contact a dealer on your behalf, you can PM me your VIN and contact information. Hope you have a great day!
    Austin J.
    Cadillac Customer Care
    Jul 2010
    Clark, NJ
    4
    I have a Actron CP9180 scanner tool but my knowledge of using it is limited. I checked the misfire count and for the last 10 driving cycles the EWMA misfire count (average) is Cyl 1=9, Cyl 2=1, Cyl 3=1, Cyl 4=0, Cyl 5=0, Cyl 6=2. Cylinder one seems worse than the rest, are these number normal?
    Apr 2009
    Ledyard, CT
    37
    9,158
    No, they are not normal. It should have a zero at all of them. However, since cylinder one has 9 misfires that would be the one that I would replace. Once replaced, the other's should act normal with a zero count. I can foresee cylinder one causing a misfire on the other cylinders. As they are all connected, obviously.
    So replace that coil pack on cylinder one...
    Front most cylinder on passenger side.
    This is a picture of the engine with the top removed and as if you are standing in front of the car.
    KOT
    Argent1, RCVW and epchavez like this.
    Jul 2010
    Clark, NJ
    4
    I changed the number one cylinder coil a week ago and not a single misfire since. It never idled so good. thanks for your help!!!
    Tom's Caddy likes this.
    Marksko is offline Cadillac Owners Member
    Automobile(s): 2007 cadillac cts 3.6
    Jul 2014
    26
    1
    I have the same problem already replaced all spark plugs and #1 coil pack,cleaned injectors replaced fuel filter. Going crazy
    Pwayne is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Jun 2008
    185
    Me too. Car runs perfect. No codes. Only misfires at full idle. I live in Florida so AC is normally on, turning AC off it almost never misfires. With AC on and misfiring (randomly, maybe every few seconds to only a couple of times a minute) I can barely increase idle RPM to 750 and the misfiring stops.
    I have HP tuners, which comes with a live scanner, and it detects nothing. I did have 1 bad coil a year ago and the HP Tuner scanner told me exactly which cylinder was misfiring. This time nothing.
    The difference is, when I had a bad coil, the car would randomly misfire at any RPM. This time it only misfires at full idle. It will run to red line without a sputter.
    Ideas?
    Static1120 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS 3.6
    Feb 2014
    20
    353
    same issue here, car misfires very noticeably upon cold start up, after about 30-45 seconds the car levels out with only random misfires and shrugs randomly. other than than no misfires at all across the rpms.
    following the ideas on this thread would be a good start, I might look into live misfires to see if I can find a specific coil throwing errors.
    Henry06cts is offline Cadillac Owners Member
    Automobile(s): 06 cts 3.6l
    Jun 2015
    27
    Im having the same issue with my 06 cts with the 3.6 liter with ac one it start missing timing chain just got replaced 2k miles ago im lost dont know were to start any help?
    the cadillac man's Avatar
    Mar 2011
    speedwell tn,
    11,884
    I would check the injectors
    They can cause misfires and it not throw a code
  14. Remove Advertisements
