Still have that famous R/R floor water leak?
Results 1 to 11 of 11
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Still have that famous R/R floor water leak? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; All 4 sunroof drains are working but still have this water leak, pics attached, comments please !! I'm at my ...
    ziggie is offline Cadillac Owners Fanatic
    Automobile(s): 2003 CTS
    Jan 2007
    N.E. Fl.
    432
    I'm at my wits end ---- can you see the little opening in the door seal? Is this normal because on my 2003 cts -- both rear door seals have the same opening.
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    37
    9,122
    Re: Still have that famous R/R floor water leak?
    Have you checked the little weeping hole that is at the bottom of your doors? Gently tug on the door seal on the bottom and you should be able to see/feel the weeping holes. If I recall correctly, it is in the center of the door for the rear.
    KOT
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    doubtful that it's the door seals (or at least those door seals)
    if the drains are not kinked then the weatherstrips that are on the body of the car around the door openings will be the next place to look
    after that make sure that water is not getting in the door past the vapor barrier and coming in behind the door trim panel
    those on the door weatherstrips are not there to keep water out of the car so it's definitely not them
  5. #4
    Jan 2007
    N.E. Fl.
    432
    What is the black goo that's around the plastic OR what can the I use from my Auto-store?
  6. #5
    Jan 2007
    N.E. Fl.
    432
    Well, I've pulled the door's inside panels off and checked all the vapor barrier's and there all good.
    I'm going to jack up the rear of the car to pull the wheels and remove the wheel/wells to double check all sunroof hoses.
    Post up later!
  7. #6
    Apr 2009
    Ledyard, CT
    37
    9,122
    When you removed the door covers. Did you notice any signs of water stains? Or did the stuff look like it hasn't been touched by water.
    KOT
  8. #7
    Jan 2007
    N.E. Fl.
    432
    No, haven't seen the problem ---- yet !!
    Everything so far looked good.
  9. #8
    Apr 2009
    Ledyard, CT
    37
    9,122
    I was asking if there was any sign that there was water inside the door? Whether it was filled with water when you opened it or in the past.
    KOT
  10. #9
    Jan 2007
    N.E. Fl.
    432
    Yes, there has been water in both rear doors in the past but I want to ID how water get's into the right rear floor board area !!
  11. #10
    Apr 2009
    Ledyard, CT
    37
    9,122
    Then I can tell you it's possible that it came from the door. Because I had the same problem a few years ago where water was pooling in my right rear foot well. Since I have no sun roof, it had to be coming from the door. My girl friend opened the right rear door and it started to leak. It poured a day or two before. So I felt under the door for that weeping hole, found it in the center and removed debris that was blocking it. Then all of sudden about a gallon or more of water poured out of the door. Since then it's been dry inside the car.
    KOT
  12. #11
    Jan 2007
    N.E. Fl.
    432
    Yes and thanks for the on going help, sounds like I have the same problem as yours!
    The answer is 'Yes' --- when I first understood I had a wiring problem in the R/R floor area, water was running out the R/R door speaker, and again 'Yes' water was pouring our the holes in it's door after playing around with it's door sealer on the bottom.
  13. Remove Advertisements
