OK Guys (and Gals) I just walked in the door.
First special thanks to Fast Specialties in Vancouver,WA. They let me use their shop and a dyno technition for about 4 hours today at no-charge. If you can throw any business their way it would be appreciated. They do carry Volant and K&N.
http://home.fastspecialties.com/
The test results were a little surprising. One thing was very clear, this was a great comparison of the kits but not of the potential of the engine. The motor was pulling right up to the top speed cutoff at 140mph/6000 rpm in 4th gear. It will be very interesting to see how much more it will make with this switched off.
Test Vehicle, 2006 3.6 VVT 5 speed auto, no modifications to powertrain.
Shop temperature was a constant 68°
Car never got hot at all, temp needle straight up the whole time.
Fuel, Chevron Unleaded Supreme 92 octane
Dyno operator was experienced in running late model auto trans cars and had no problems slowly rolling on the throttle to prevent a down shit.
Runs were made in 4th gear, TC off.
STOCK INTAKE
splash guard in place, radiator air deflector in place. lower valance panel in place.
220 RWHP
TONY A MODIFIED STOCK AIR BOX
splash guard cut to match opening (supplied by Ody). Lower valance panel removed.
225 RWHP
made a few more HP than stock all through the rpm range
K&N FIPK KIT
splash guard removed. lower valance panel removed
A quick spike at the end showed 236 hp but 228 hp what showed on the screen on both runs.
228RWHP
VOLANT
splash guard removed. radiator air deflector folded over to expose front snorkle.
233 RWHP
consistant each run.
IMO the K&N was not worth the addtional noise. The differnce in the 2 intake tubes is obvious when side by side. The K&N take a sharp radius into the throttle body to clear the electric fan mounting stud. The Volant sweels up around the stud in a bulb that allows a clearer entry for the air into the TB. They took the time to do it right.
Overlayed dyno sheets scanning now.
There ya go folks.
