3.6 Engine swap --- help please
Results 1 to 5 of 5
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 3.6 Engine swap --- help please in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I'm about to buy an '07 3.6 to swap into my '06 CTS, replacing the old 3.6. Should I remove ...
    AlanEdwards is offline Cadillac Owners Member
    Automobile(s): 2006 CTS
    Mar 2010
    Tampa, FL
    22
    Should I remove the tranny along with the old engine, mount the tranny to the "new" one, and put them both back in together, or should I dismount the engine from the tranny and leave it in the car while I pull the engine out, then remount the "new" engine to the tranny while it's still in the car?
    Thanks!!!
    Alan
    mattt0305's Avatar
    mattt0305 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 6 speed manual tarnished platinum
    Feb 2011
    Southern Illinois
    333
    Re: 3.6 Engine swap --- help please
    Mar 2010
    Tampa, FL
    22
    Thanks very much Matt, but I saw that thread in my initial searches. I was wondering if someone new for sure that it was better to take the tranny out too, as opposed to leaving it in like Brifinny did. Just because he left it in doesn't mean that it's best to leave it in, as he's a self-described shadetree mechanic. There's got to be someone here that can answer that question for sure.
    mattt0305's Avatar
    Feb 2011
    Southern Illinois
    333
    Well I did my clutch and pressure plate etc. If you can pull them as a single piece I would. If the auto is anything like my manual those bell housing bolts are a bear. One in particular is right behind the outlet pipes for the heater core you MUST remove the pipe assembly if you pull the trans first.Get a gasket and o ring for it. And don't mess with the heater hoses at the engine side take them loose at the core side and replace them while its all out. Also to clear the firewall you have to drop the back of the cradle two inches and rotate the trans clockwise 90 degrees. To drop the cradle too you must disconnect the steering intermediate shaft at the rack. Ideally seems that dropping them together from the bottom on a lift is the way to do it. Those trans bolts are external torx e14 if I remember right. One of those hose clamp pliers with the cable made my life a whole lot easier.
    Mar 2010
    Tampa, FL
    22
    Thanks again Matt. I didn't consider pulling the engine and tranny from the bottom. I figured I'd have to pull from above, tilting the two while coming out and back in. I'll be doing the job at the Auto Hobby Shop at MacDill AFB here in Tampa, FL, giving me access to bays with and without lifts, and more than likely all the tools I'll need. I like the idea of R&R-ing them together from below. It seems it might be smarter to go that route. If I remember correctly, the factory actually puts them in from the bottom.
    Since Matt has a manual tranny, I'll ask this... Is there anyone here that knows for sure that going at it from the bottom with an automatic tranny is better? Or should I go the traditional route of R&R-ing them from above?
    Thanks for the tips Matt.
  8. Remove Advertisements
