Cruise Control stopped working....
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By Kingoftypos
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Cruise Control stopped working.... in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; So I've found a few people ask this question here using search but nothing really answered my question. I need ...
    Bick is offline Cadillac Owners Member
    Automobile(s): 2005 CTS
    Jan 2013
    WV
    24
    14
    QuestionCruise Control stopped working....
    So I've found a few people ask this question here using search but nothing really answered my question. I need to know what to look for before I take it into a shop (btw would any normal car shop even know where to start with fixing this or would I have to take it to a dealership?).... I'm not incredibly knowledgeable with mechanic type things with cars so I'm not sure where to look. I do know where the fuses are... but I don't know which one or ones would work cruise control... I looked around on the manual and can't seem to find anything about it!
    Any advice is appreciated very much.
    briggy's Avatar
    briggy is offline Cadillac Owners Enthusiast
    Automobile(s): CTS 3.6L 2005 80,000 Miles
    Dec 2009
    Southern California
    41
    958
    Re: Cruise Control stopped working....
    define stopped working. In the sequence of setting the cruise control, at what point does the car not do what is expected. ie when you click cruise does the light come on, and the car not maintain speed, or is it as though the botton doesn't work. Is the check engine light on, if so what codes do you have. It could be as simple as a bad switch, and as complex as a funky module. be more descriptive in what the car is or isn't doing
    Jan 2013
    WV
    24
    14
    I press the button and nothing happens... like the green cruise control light in the dash doesn't turn on like it used to. No check engine light, no codes.... idk if that would mean the button isn't working or cruise control won't turn on for some reason
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,222
    I won't have the manual in front of me for a whole. But I must ask you to have someone drive behind you to see if your brake lights are constantly on. Don't just start the car and get out while parked, it may not show a problem unless you're driving.
    KOT
    mattt0305 likes this.
    Apr 2009
    Ledyard, CT
    38
    9,222
    I see 4 fuses, two are under the hood and the other two are some where in the steering column.
    The two under the hood are labeled HTR VLV/CLTCH 10 amp fuse, though this maybe on the manual transmission only. The second is STRG CTLS 10amp fuse.
    The two that are some where in the steering column are 2 amps each. One is inline with the actual "on/off" switch. While the other is inline with the "Set/Coast" push button. They appear to be between the clock spring and the car. This is for a 2005 CTS, which is your's anyways.
    For my 2006 CTS, it doesn't make sense to have the clock spring involved because it shouldn't go through it. But there again, I've seen some strange things go through some strange areas.
    KOT
    Hannu_L is offline Cadillac Owners Member
    Automobile(s): CTS 3,2 Sport Luxury -03
    Nov 2012
    6
    Do you have Cruise buttons on the steering wheel? If so, when you press left button does it stay in bottom and is there light when its on?
    Jan 2013
    WV
    24
    14
    ok I will have someone check behind me for brake lights! and I will check those 2 fuses in the hood.... I'm not sure how to go about checking the ones in the steering column... I guess I'll figure it out haha
    and I don't have cruise control buttons on the steering wheel
    Argent1's Avatar
    Argent1 is offline Cadillac Owners Connoisseur
    Automobile(s): '07 CTS 3.6
    Nov 2010
    2,937
    Not to be a smartass, but is the slider switch on the stalk in the on position? Sometimes it gets bumped by accident.
    Jan 2013
    WV
    24
    14
    yeah haha its on. I definitely know how to use it... I was in love with it until it broke
  12. Remove Advertisements
