100K Maintenance Suggestions for an '07 CTS
Results 1 to 7 of 7
Like Tree7Likes
  • 2 Post By mattt0305
  • 3 Post By cswimc
  • 1 Post By Kingoftypos
  • 1 Post By mattt0305
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 100K Maintenance Suggestions for an '07 CTS in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; So, I've reached the 100k mark this month and it's time to think about normal maintenance. Recently I got a ...
    cswimc is offline Cadillac Owners Member
    Automobile(s): 2007 CTS Sports Sedan
    Feb 2011
    39
    So, I've reached the 100k mark this month and it's time to think about normal maintenance. Recently I got a check engine light that turned on and off on its own a few times, but has decided to stay on now. The error code indicates the engine is misfiring and I've determined that it's most likely the spark plugs. I got a quote from the dealership for $700 to change the spark plugs but I think that is excessive. Does anyone have any idea the normal cost of this? Also, what other things should I have them check out being that I'm just over 100k?
    mattt0305's Avatar
    mattt0305 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 6 speed manual tarnished platinum
    Feb 2011
    Southern Illinois
    333
    Re: 100K Maintenance Suggestions for an '07 CTS
    I did my plugs for the cost of the plugs. Ac delco like 18 bucks. Look in FAQ there's a writeup on how to do it. Have to take loose the intake manifold. I can't fathom how they could justify 700 dollars for that.
    CTSjones and SHORTSTACK like this.
    ztollon's Avatar
    ztollon is offline Cadillac Owners Enthusiast
    Aug 2012
    629
    700 is excessive considering a good mechanic could have it done in an hour. If youve done all the pre-100k maintenance: coolant flush, trans flush and filter, power steering flush, cabin/air filter, fuel filter/ fuel system flush, diff flush, there shouldnt be much to do. Plugs would be the best place to start. Then swap coils until you find the cylinder misfiring. thats if the plugs dont do the trick.
    Feb 2011
    39
    UPDATE:
    After getting quotes for $700 and $300 give or take from a local shop, I went to Advanced Auto Parts with a friend (who is a skilled hobbyist that flips cars), shelled out $18 for 6 Double Platinum spark plugs and spent the morning replacing them. It took a few hours and we were able to follow the guide from the sticky post - http://www.cadillacforums.com/forums...ug-change.html - and changed them all out.
    Here was the culprit - spark plug from Cylinder 2 - that was misfiring (see pic)
    (removing the spark plug)
    Faulty spark plug that was misfiring
    Since changing it out I drove 60+ miles with no check engine lights coming back on (we reset the obd2 codes with a scanner), and the car ran smoothly with no hesitations, vibrations, jerking, or anything. All in all I believe the problem is solved, and for a mere $18!
    CTSjones, s_tharsan and mattt0305 like this.
    Kingoftypos is online now Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,302
    Nice job. But how the heck did you buy 6 plugs for $18?
    They are normally $5 to 7 each.
    KOT
    s_tharsan likes this.
    Feb 2011
    39
    Advanced Auto Parts had them on sale. I placed the order online for in store pickup and applied a discount code I found online. The total was actually $19.08 (off the top of my head I though it was 18 :-X)
    Here is the receipt:
    mattt0305's Avatar
    Feb 2011
    Southern Illinois
    333
    Advance always has crazy coupons like 20% or $10 off $40 etc. I always check retail me not before I go. Feels good saving $680 dollars lol.
    concorso likes this.
  10. Remove Advertisements
