2003 Cts 3.2l Vacuum lines diagram
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Like Tree1Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 2003 Cts 3.2l Vacuum lines diagram in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Does anyone know if there is a diagram of the vacuum lines for a 3.2L. Im hearing an air leak ...
    garciajoaquin's Avatar
    garciajoaquin is offline Cadillac Owners Member
    Automobile(s): CTS
    Feb 2013
    74
    Unhappy2003 Cts 3.2l Vacuum lines diagram
    Does anyone know if there is a diagram of the vacuum lines for a 3.2L. Im hearing an air leak that might cause misfire on cyl 2,4,6.
    briggy's Avatar
    briggy is offline Cadillac Owners Enthusiast
    Automobile(s): CTS 3.6L 2005 80,000 Miles
    Dec 2009
    Southern California
    41
    958
    Re: 2003 Cts 3.2l Vacuum lines diagram
    Tried to respond to you but it says you've maxed out yoru quota. see below
    Each bank has two if I recall. On either side you will see a ground to the cam cover, one mid cover the other in the rear. They are pretty easy to trace out if you go from where the injector wiring portion of teh harness connect to the main harness. There is a connector on the passenger side above where the ECM is.
    Good luck
    Automobile(s): CTS
    Feb 2013
    74
    Thanks Briggy i know i erased my inbox which was 2 messages. ok because i bought the ignition coil installed it last night and its the same. Do you have any pics?
    Planktron's Avatar
    Planktron is offline Cadillac Owners Fanatic
    Automobile(s): 03 CTS 5M Luxury/Sport: V rear bumper and V exhaust
    Aug 2013
    Tampa, FL
    31
    172
    I suggest spraying starting fluid on all your vac lines, when you hear the idle raise, you've found your leak.
    Sent from AutoGuide.com Free App
    TunixComplex likes this.
    Automobile(s): CTS
    Feb 2013
    74
    I havent had a chance to work on my car but i started taking it apart and the vacuum line snap. Is there a link where i can get these lines. I am talking about the ones that connect to the air box canister.
    Its actually called the reservoir air tunning
    Ikera's Avatar
    Ikera is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac CTS 3.2, 1990 Nissan 240sx Turbocharged
    Apr 2013
    Vancouver, BC
    30
    383
    I would not bother replacing or fixing those lines, the are useless for the most part, make it more difficult to work on the car and potential vacuum leak waiting to happen.
    you can remove the vacuum reservoir box and all vacuum lines around the intake ducting. And just plug in the variable intake actuator from the back of the intake manifold directly into a vacuum source. (from the brake booster T-Fitting which is already there and would need to be plugged anyway)
    I've done that when I replaced my timing belt few weeks ago without any problems and no engine check light either
    Before
    After
    But if you really want to fix your broken plastic vacuum line, you can use a piece short piece or silicon or rubber vacuum line (ID: 1/8" or 3mm) and just slide it over the cracked portion of the line.
    Automobile(s): CTS
    Feb 2013
    74
    Thanks @ikera. By any chance do you know if there are any pictures of the ground terminals to the injector circut. I am having misfires in one bank.
    Automobile(s): CTS
    Feb 2013
    74
    I checked the ground wires to the injectors, sparkplug gap, coils, vacuum lines, and have come out to the conclusion my valves might have bent. Somebody tried to help me with the timing acouple months back and ran the car and since then it has not ran well. Taking apart cylinder head and check for valves next.
    Ikera's Avatar
    Apr 2013
    Vancouver, BC
    30
    383
    or better do a compression test before you take everything part
    even if the compression test is weak in one bank it could be that your timing is off and valve might still be okay
    (it's possible for the valve timing to be off while not making contact with the cylinder)
    also a while back I replaced Upstream O2 sensor with a cheaper brand, after that I had strange codes pop up (I think one of them was about injector) and misfire.
    So codes that you may pull up might not always be the actual problem that is causing the codes
    what kind of spark plugs did you use and I'm curious how did you rule out that it is not the coil pack?
    mcstlouis is offline Cadillac Owners Member
    Automobile(s): None
    Feb 2014
    1
    My 2003 CTS is doing the same thing, a misfire with a rough idle. I replacedspark plugs with Bosch, replaced fuel filter, tried to clean the throttle body be cause it was full of carbon and might need to just remove it to clean good. I also heard the throttle positioning sensor could be covered in carbon and malfunctioning. I bought passenger side coil pack and am curious if there is a way to check the ignition coil with out replacing them?? An did you ever figure out the pro lem with the misfire
    Please update your profile to show correct birthday, car owned and time zone.
    Automobile(s): CTS
    Feb 2013
    74
    @Ikera i used Autozone Ac Delco spark plugs and i bought an OEM Coil pack as well and the misfire codes are still p0300, P0302 p0304,P0306. Checked ground wires as well all are correct.
    cabletech is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS 3.2L M35 LtPt
    May 2010
    223
    If you permanently remove the vacuum line going to the radiator bypass valve (on a 3.2L motor), your car will not warm up in the winter unless you force the valve closed 100% of the time. Without vacuum / engine running, it's open. That's what was causing my P0128 code for the last 2 years - a bad vacuum solenoid.
    Automobile(s): CTS
    Feb 2013
    74
    I just did a compression test of lowest 190 with highest 210. Tested all cylinders and all sides read about the same. Can a cam sensor be causing misfires on one side only or would it affect both sides ?
  16. #14
    Ikera's Avatar
    Apr 2013
    Vancouver, BC
    30
    383
    Quote Originally Posted by cabletech View Post
    I guess that would be possible under certain conditions
    here is a diagram that might help understand as to what the by-pass valve is doing
    however the diagram is a little misleading, because there are more water loops in the system that are not shows, also they are not showing the location of the thermostat, but if you know about engines this diagram should make sense.
    I didn't have the code pop up (probably because it doesn't get very cold here in winter) but I'm planning on removing that valve. "By-Passing the By-pass valve"
    Quote Originally Posted by garciajoaquin View Post
    that narrows it down a lot and it's a good thing you didn't start taking the heads off.
    AFAIK the cam sensors are interchangeable. Maybe try to swap them from bank to bank, next maybe take a look at the knock sensors and wiring, it could the knock sensor throwing the faulty codes.
  17. #15
    Automobile(s): CTS
    Feb 2013
    74
    Does each cam have a sensor or only one per bank?
  18. Remove Advertisements
