changed timing belton my 03 3.2 cts, sounds like a diesel or loud tapping noise :(
Results 1 to 6 of 6
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, changed timing belton my 03 3.2 cts, sounds like a diesel or loud tapping noise :( in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I just changed the timing belt, thermostat, waterpump and spark plugs on my 03 CTS with the 3.2L at 100k ...
    neonzion is offline Cadillac Owners Member
    Automobile(s): 2006 Cadillac SRX, 2003 Cadillac CTS
    Jan 2013
    22
    6
    I just changed the timing belt, thermostat, waterpump and spark plugs on my 03 CTS with the 3.2L at 100k miles. I made sure all the vacuum lines were good before starting and it started up. There is a loud diesel like sound/tapping sound. Please help
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,055
    Re: changed timing belton my 03 3.2 cts, sounds like a diesel or loud tapping noise :
    I would check your belt again, make sure it's lined up properly. I would definitely not start that engine again until you can validate the belt is installed correctly.
    Jan 2013
    22
    6
    i really feel like blowing this crap car up. i guess i have to remove all that stuff again. i hate this engine
    Ikera's Avatar
    Ikera is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac CTS 3.2, 1990 Nissan 240sx Turbocharged
    Apr 2013
    Vancouver, BC
    31
    383
    scary stuff, the timing could be off on one of more cams. how was the idle when you started it first time? and did any new codes show up? IIRC These engines have 2 cam sensors and a crank sensors that might throw a code if the timing is off
    Quote Originally Posted by neonzion View Post
    note: if you didn't know this already the alignment marks on the belt will not line up with the alignment marks on cams after the first revolution, however the alignment tool work fine.
    think on the bright side, the timing belt is a lot easier to replace than a timing chain on 3.6L
    Jan 2013
    22
    6
    i am beyond overwhelmed. im 19 and can literally do anything on a jeep but this is my dads CTS and this is a huge disappointment. i hate this cadillac and want to crush it with my jeep. nothing aligns. im going to throw it all back and let a mechanic deal with this POS car
    great news.. while working on it, the cams slipped. yay so what, is my engine done for?
    Jan 2013
    22
    6
    well even after the cams slipped, i was able to realign everything and throw it all back together. the diesel sound remains but no real signs of bent vales. hmmm
  9. Remove Advertisements
