Traction Engaged coming on in dry conditions
Results 1 to 12 of 12
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Traction Engaged coming on in dry conditions in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hey everyone, need a little help. I recently had snow tires put on my 07 2.8 CTS. Ever since, I've ...
    harporu is offline Cadillac Owners Member
    Jul 2012
    17
    Hey everyone, need a little help. I recently had snow tires put on my 07 2.8 CTS. Ever since, I've been getting the Traction Engaged warning showing up on my DIC at random times. And when it does come on, it seems like it doesn't want to shift properly. And I must add that it will come on in totally dry conditions! Any help is appreciated. Thanks !
    Kingoftypos is offline Cadillac Owners Master
    Apr 2009
    Ledyard, CT
    38
    9,254
    Re: Traction Engaged coming on in dry conditions
    What are the sizes of All four tires? Please post your answers for each one.
    KOT
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,697
    Quote Originally Posted by harporu View Post
    Hello harporu,
    I apologize that you are experiencing a concern with your traction control engaging at random times after you had snow tired put on your vehicle. Are you planning on taking your CTS to a dealership to look further into this concern? I would be more than happy to assist you in setting up an appointment to look further into this, please feel free to private message me.
    Gregory W.
    Cadillac Customer Care
    Jul 2012
    17
    Quote Originally Posted by Kingoftypos
    What are the sizes of All four tires? Please post your answers for each one. KOT
    KOT, thanks for the reply. My two fronts are 225/55/16, the two snow tires are 225/50/16. Will the extra width really matter? Thanks again!
    Apr 2009
    Ledyard, CT
    38
    9,254
    Extra width no. But you have the same width. However, you do have extra sidewall. Meaning your 225/55R16 are larger in diameter. And that is why your receiving the traction engage problems. If I recall correctly, the 225/55R16 is correct. It's the 225/50R16 that is too small.
    KOT
    curtc's Avatar
    curtc is offline Cadillac Owners Master
    Automobile(s): 2006 STS V8 1SF RWD
    Jul 2005
    Oakdale, MN
    31
    6,055
    Back wheel is rotating more times than the front due to the smaller diameter, that's why TC is engaging.
    Jul 2012
    17
    Quote Originally Posted by curtc
    Thanks guys for the help. Am I to assume this won't hurt anything?
    mattt0305's Avatar
    mattt0305 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 6 speed manual tarnished platinum
    Feb 2011
    Southern Illinois
    333
    Since the rear wheels are turning faster it thinks they're slipping or spinning so it reducing your ability to accelerate which could be dangerous when you go to pass or merge.
    Apr 2009
    Ledyard, CT
    38
    9,254
    It may, because the way that traction control works. It basically applies the brakes to the wheel(s) that's spinning. Or in your case the one that the car thinks that is spinning.
    However, get into the habit if disabling the Traction Control. Button is located in the glove box. Or you can program it onto one of the buttons on the steering wheel or radio.
    Or better yet, get proper size tires.
    In the past, you could get away with different size diameter tires. But with all the sensors and what not. Tire sizing does matter.
    KOT
    mattt0305's Avatar
    Feb 2011
    Southern Illinois
    333
    The problem here originally is "will the extra width really matter?" I don't know how many people I've met think that the aspect ratio number is the width. I argued with a guy at a tire store behind the counter once about it. The op probably thought he was just getting wider tires not shorter ones. I think it comes from the early days of low aspect tires and they were on like c4 vettes and the tires were like steamrollers compared to everything else. 50% of 225mm is a 112.5mm sidewall height versus 123.76 mm for the 55s. So your fronts are roughly a half inch taller sidewall than the back ones x2 for the top and bottom an inch overall diameter.
    Apr 2009
    Ledyard, CT
    38
    9,254
    Quote Originally Posted by mattt0305
    There's no extra width between the two sets or tires he has. So that shouldn't be a question. The fact is that his snow tires, mounted on the rear, are smaller in diameter just enough that it messes up the computer.
    KOT
    mattt0305's Avatar
    Feb 2011
    Southern Illinois
    333
    That's what I was trying to say the quote was from the OP in post #4. 225 is the width 50 or 55 is the percentage of the width that is the sidewall height. His rears are an .88 inch overall diameter smaller. I ran it through a tire diameter calculator.
  15. Remove Advertisements
