03 cts won't start
Results 1 to 9 of 9
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 03 cts won't start in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hey guys this is my first post. I have an 03 cts with about 193 thousand miles. Couple weekends ago ...
    gannon cts's Avatar
    gannon cts is offline Cadillac Owners Member
    Automobile(s): 03 CTS. 04 SRX
    Dec 2013
    Nebraska
    8
    Hey guys this is my first post. I have an 03 cts with about 193 thousand miles. Couple weekends ago replaced thermostat and while I had it broken down that far decided to replace valve cover gaskets,spark plugs, and timing belt. Put it all back together and it ran for two and a half days. Shut down on the highway. Tried to restart it a couple of times and made a terrible sound like plastic rubbing. So towed it home took off hoses to intake to get some room to investigate. Timing belt had came loose. So adjusted it. And now will start maybe once in five attempts. And sounds really rough and dies. Have code p0341. Just wondering where to go next? Are valves bent? Can it be fixed?
    Planktron's Avatar
    Planktron is offline Cadillac Owners Fanatic
    Automobile(s): 03 CTS 5M Luxury/Sport: V rear bumper and V exhaust
    Aug 2013
    Tampa, FL
    31
    172
    Well, you could do a compression test, but it won't tell you for sure if the valves are wrecked or if the cams are just not timed correctly. The 3.2 IS an interference motor, so I'd prepare for the worst.
    Sent from AutoGuide.com Free App
    gannon cts's Avatar
    Dec 2013
    Nebraska
    8
    [QUOTE="gannon cts"]Hey guys this is my first post. I have an 03 cts with about 193 thousand miles. Couple weekends ago replaced thermostat and while I had it broken down that far decided to replace valve cover gaskets,spark plugs, and timing belt. Put it all back together and it ran for two and a half days. Shut down on the highway. Tried to restart it a couple of times and made a terrible sound like plastic rubbing. So towed it home took off hoses to intake to get some room to investigate. Timing belt had came loose. So adjusted it. And now will start maybe once in five attempts. And sounds really rough and dies. Have code p0341. Just wondering where to go next? Are valves bent? Can it be fixed? Ran a compression test on left side. No compression!
    Ikera's Avatar
    Ikera is offline Cadillac Owners Fanatic
    Automobile(s): 2003 Cadillac CTS 3.2, 1990 Nissan 240sx Turbocharged
    Apr 2013
    Vancouver, BC
    30
    383
    Re: 03 cts won't start
    sorry to hear that, that must be frustrating specially after doing all that work on the engine. Do you know what went wrong? was the tension not set right or did one of the tensoners failed?
    gannon cts's Avatar
    Dec 2013
    Nebraska
    8
    Quote Originally Posted by Ikera
    Tension wasn't set right I'm assuming. Now figured out that valves are bent on drivers side. So now in search of a new cylinder head. Or new engine. Just have to do some checking into prices. Any ideas?
    gets even more frustrating now. Tore it down and found bent valves on drivers side. Now in search of a new cylinder head. Any suggestions?
    Quote Originally Posted by Planktron
    Well, you could do a compression test, but it won't tell you for sure if the valves are wrecked or if the cams are just not timed correctly. The 3.2 IS an interference motor, so I'd prepare for the worst. Sent from AutoGuide.com Free App
    well the worst is here need new cylinder head
    need new cylinder head. Valves are bent and stays open thus no compression. Any good sources for parts anyone?
    Planktron's Avatar
    Aug 2013
    Tampa, FL
    31
    172
    I posted this site in another thread also. Dunno if they ship or not but I've had great luck with them. It's worth a shot if you can't find a similar place locally.
    http://langstonsauto.reachlocal.net
    gannon cts's Avatar
    Dec 2013
    Nebraska
    8
    I posted this site in another thread also. Dunno if they ship or not but I've had great luck with them. It's worth a shot if you can't find a similar place locally. http://langstonsauto.reachlocal.net Sent from AutoGuide.com Free App
    Appreciate it. I guess I just don't know what to do. Do I replace just the one with bent valves? Do I replace them both? Is replacing them gonna fix the car? Do I find a used motor and swap out the whole thing?
    jran0823's Avatar
    jran0823 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS 1SC Luxury Sport
    Apr 2011
    GB, WI
    30
    1,017
    Find a good machine shop and bring the head to them to have it rebuilt. It's usually best to do both, better to know both heads are good if the other doesn't need any work after tearing it down that far....again
    Ikera's Avatar
    Apr 2013
    Vancouver, BC
    30
    383
    Quote Originally Posted by gannon cts View Post
    Sorry few more off topic questions,
    - But what brand timing belt did you use
    - Did you reuse old tensoners or installed new
    - Did you reset the tension or left them as is
    I planning a replace a my timing belt soon also, already go "Gates" Belt and water pump
  12. Remove Advertisements
