2003 Cts 3.2l misfire.
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, 2003 Cts 3.2l misfire. in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hey Guys this is my first post. I have a 2003 Cts 3.2l with 89k miles and i just replaced ...
    garciajoaquin's Avatar
    garciajoaquin is offline Cadillac Owners Member
    Automobile(s): CTS
    Feb 2013
    74
    Angry2003 Cts 3.2l misfire.
    Hey Guys this is my first post. I have a 2003 Cts 3.2l with 89k miles and i just replaced my head gasket, sparkplugs, water pump, oil cooler, timing belt, intake gaskets; because i was getting oil in my water system. Problem is now that im getting engine codes p0300, p0302, p0304, p0306 and pending p0302, p0304, p0306. I gapped all my spark plugs to 0.053 and still having the codes. I was wondering if it might be the timing belt.
    jran0823's Avatar
    jran0823 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 CTS 1SC Luxury Sport
    Apr 2011
    GB, WI
    30
    1,017
    2,4, and 6 are all on the same coil. It could be a bad coil, or the belt could be off. Line up your marks and see where everything falls. Then go from there.
    Automobile(s): CTS
    Feb 2013
    74
    Re: 2003 Cts 3.2l misfire.
    Ok i sure will work on that. This car has been a pain in the a$$ to fix.
    briggy's Avatar
    briggy is offline Cadillac Owners Enthusiast
    Automobile(s): CTS 3.6L 2005 80,000 Miles
    Dec 2009
    Southern California
    41
    958
    Do a compression test to rule out a misaligned head gasket, or valve issues. Then recheck your wiring for your coil packs & injectors. Make sure all your grounds are correctly seated. When I did my rebuild I had a similar issue and it was because I never tightened down one of the ground terminals on the injector circuit.
    Quote Originally Posted by garciajoaquin View Post
    Automobile(s): CTS
    Feb 2013
    74
    I checked my timing belt and compression test. All good. Next going to check my ground cables for the coils.
    Automobile(s): CTS
    Feb 2013
    74
    @briggy where is the ground to the injector circut.
    Teedoe's Avatar
    Teedoe is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS Base and 2014 Cadillac CTS VSport Premium
    Dec 2009
    Central Florida
    527
    I also read that you can check the fitting of the fuse box under the hood. Wires could be loose.
    Automobile(s): CTS
    Feb 2013
    74
    Oh ok i will check that next. Thank you.
    Antsrcool is offline Cadillac Owners Member
    Automobile(s): none
    Sep 2009
    33
    7
    if your a couple teeth off on one of the cams it wont show up in a compression test. Need to pull that cover to make sure all lines up well.
    Automobile(s): CTS
    Feb 2013
    74
    I did pull out the timing cover and all lines up . im thinking a vacuum leak.
    Automobile(s): CTS
    Feb 2013
    74
    neriah is offline Cadillac Owners Member
    Automobile(s): CTS
    Jan 2014
    28
    did you replace all the coil packs? I'd start there.
    Automobile(s): CTS
    Feb 2013
    74
    No I have not replaced the coil packs. They run 95 for each. Ouch. Im Thinking its a vacuum line problem because during the time of putting the car together we lost track where the vacuum lines went.
  16. #14
    jran0823's Avatar
    Apr 2011
    GB, WI
    30
    1,017
    If it was a vacuum line the misfires wouldn't be isolated to one bank.
  17. #15
    Automobile(s): CTS
    Feb 2013
    74
    OOoooo i see. Is there any way to test if the coil pack is bad.
  18. Remove Advertisements
