Where is this leak coming from??
Results 1 to 11 of 11
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Where is this leak coming from?? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Ok so It's raining out and I noticed this spot inside the rear area behind the driver's side on the ...
    Tony G is offline Cadillac Owners Member
    Automobile(s): 2007 CTS
    Aug 2011
    Hanover, MD
    16
    Ok so It's raining out and I noticed this spot inside the rear area behind the driver's side on the rear panel. It's wetto the touch as if I have a leak somewhere! I have no idea as I have visually inspected the back glass and surrounding areas trying to figure out just what the heck is going on with my 2007 CTS? Any help in here?
    Going crazy in Maryland!
    hrpatel17926 is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS, 2007 ESV
    Sep 2012
    The city of the 500
    46
    263
    If I am not mistaken it might be the sun roof drain. I periodically blow mine out with air there are 2 holes one each side of the frame structure. Check and see there are no obstructions there. If not that then not sure what that could be.
    Aug 2011
    Hanover, MD
    16
    Problem with that analysis is that I have no sun roof!! I'm so frustrated with this car and to think it's the exact car that I wanted!
    holsgo is offline Cadillac Owners Fanatic
    Automobile(s): 2007 cts
    Apr 2011
    143
    Re: Where is this leak coming from??
    I'm betting window seal or door seal. I'm going to walk around mine and see what makes sense. If there is no sunroof then the water is either coming in via the trunk seal or door seal. I don't see any other panel breaks.
    Cadillac Cust Svc's Avatar
    Mar 2010
    Detroit, USA
    12,687
    Quote Originally Posted by Tony G View Post
    Hello Tony G,
    I apologize that your CTS is experiencing this leak inside your vehicle. I do see that you are reaching out to the community for any of their suggestions regarding this concern. If you plan on taking your CTS to a Cadillac dealership, I would be more than happy to assist you in setting up an appointment with the dealership to look into this concern further. Please feel free to private message me if you would like my assistance in working with the dealership.
    Gregory W.
    Cadillac Customer Care
    Aug 2011
    Hanover, MD
    16
    I don't have an issue with going to the dealership. I have an issue with possibly being charged for an issue that I have no control over.
    satlite440 is offline Cadillac Owners Member
    Automobile(s): tec at brotherton cadillac
    Nov 2013
    48
    33
    wow cust assitance NOT to the rescue again... look and see if the rear window or quarter window has been replaced.. you will be able to tell.. all gm factory glass has a gm logo on it of an example look at your drivers door glass when it's rolled up and you will see the logo.. if any of the back windows have been replaced like a rear window for the defogger grid inop due to the tabs comming off and not being able to soder them back on they probably used a aftermarket glass and it will not have the logo...thats a clue as to where the leak is .. also if i remeber right you have a roof mounted triband antenna that also might be the culperate.. if you are handy you could pull the rear sail pannels and see if you can see water comming in . short of that you will have to pull the headlinner and water test it....thats what we would do at the dealership......
    Apr 2011
    143
    The only thing I can add is that there seems to be a seam that runs from the front of the car to the rear window. Seems to be right above the area that might get wet.
    wantboost is offline Cadillac Owners Fanatic
    Automobile(s): '06 CTS 3.6L:HID HEADLIGHT/FOGS:LED INTERIOR/PLATE/TRIANGLE:
    Oct 2010
    GTA
    339
    any luck with the leak, i have the same issue. looks likes it comiong out of the air bag symbol on mine. i only could find 2 sunroof drains. i know u dont have a sunroof. but did u find the problem
    69stangscj's Avatar
    69stangscj is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V sedan, 69 Mustang Mach I
    Jul 2013
    Dayton Ohio
    331
    I would pull the sale pannel, pull the air bag plug out and remove the screw behind it. Then, I just think it's one clip by the seat area, this will give you a better idea where the water is coming from.
    Lduttonrizzo is offline Cadillac Owners Member
    Dec 2015
    35
    1
    I have also a 2007 CTS and no sunroof! I am experiencing the same issue! It seems to happen when it rains. I thought maybe the floor board is rusted out below (haven't got underneath to check yet) I have no idea. It's completely soaked. :/
  14. Remove Advertisements
