Violent Shaking and Shuddering at 45-65 MPH only after Warming up
Results 1 to 5 of 5
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Violent Shaking and Shuddering at 45-65 MPH only after Warming up in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; 2003 CTS, 44,000 miles (Really) shakes and shudders violently. Happens after driving 10-30 miles at highway speeds. Then usually goes ...
    SPK
    SPK is offline Cadillac Owners Member
    Nov 2013
    1
    PostViolent Shaking and Shuddering at 45-65 MPH only after Warming up
    2003 CTS, 44,000 miles (Really) shakes and shudders violently. Happens after driving 10-30 miles at highway speeds. Then usually goes away after driving another 10-25 miles.
    You would think you have two flat tires the shaking is so violent
    No loss of engine power.
    Transmission shifts smoothly
    No change if the put transmission in neutral
    No change if disable Traction Control
    Happens consistently, but not at lower speeds.
    Really puzzled
    Two suggestions I've gotten re possible explanations: 1) Do another transmission flush without additive, and 2) problems with rear pinion gear binding that loosens up as it warms up.
    I've googled my problem, and have not found an identical match.
    Steve
    Kilaueasfinest is offline Cadillac Owners Member
    Nov 2013
    6
    See if there is any cupping in your tires ! Had that happen to my other car and it ended up being one of the tires was cupped !
    NoLeafClover is offline Cadillac Owners Member
    Automobile(s): 2003 CTS
    Nov 2013
    4
    Re: Violent Shaking and Shuddering at 45-65 MPH only after Warming up
    Do you feel any shaking/vibration on your steering at all or is it coming from the rear?
  5. #4
    The Rev is offline Cadillac Owners Member
    Automobile(s): 2007 CTS Luxury
    Oct 2013
    28
    36
    I had a similar problem. Not exactly, but it was close. I had 4 new tires installed and balanced. The mechanic who did the work through my used dealer also replaced the diff. fluid and rear flex disc. No vibration since!
  6. #5
    Rolex's Avatar
    Rolex is offline Super Moderator
    Automobile(s): 2008 Nissan Titan, 1996 Jeep Wrangler
    Arkansas
    40
    12,030
    Quote Originally Posted by Kilaueasfinest View Post
    This. A car with that few miles does a lot of sitting. The tires will develop flat spots from sitting in one spot constantly.
    The above post is my 2 cents....nothing more.
  7. Remove Advertisements
