*Help Needed!!* Cannot get any fluid back into transmission after drain/filter change - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Like Tree7Likes
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, *Help Needed!!* Cannot get any fluid back into transmission after drain/filter change in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I'm confused-if you removed the wrong bolt, where did the 4-5 quarts come from? And why can't the transmission be ...
  1. #16
    Jim's 06 is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac
    Nov 2006
    194
    Re: *Help Needed!!* Cannot get any fluid back into transmission after drain/filter ch
    I'm confused-if you removed the wrong bolt, where did the 4-5 quarts come from? And why can't the transmission be refilled thru the fill tube? Because it was never drained??
  2. #17
    ztollon's Avatar
    ztollon is offline Cadillac Owners Enthusiast
    Aug 2012
    629
    Quote Originally Posted by Jim's 06 View Post
    I think he pulled the drain plug, and another plug thinkng it was the fill. Emptied the fluid then upon filling ran into the no fill issue. Then couldnt get the t45 bolt for filling off. So here we are, I like the 19mm bolt idea.
  3. #18
    holsgo is offline Cadillac Owners Fanatic
    Automobile(s): 2007 cts
    Apr 2011
    143
    I've heard of this happening so I was sure to crack the fill plug first. But, I used my impact to crack it. I used some extensions and a knuckle, hooked up the impact and did a fast squeeze and release. It spun it loose about 2 threads. I stopped, screwed it back in finger tight, drained, filled, started car, completed fill and then torqued everything to spec.
    I've found that the impact is always a safer bet in releasing ( barring a breaker bar) because of the burst of the force vs slow torquing. Never impact fill bolts with impact, tighten finger tight, then ratchet until resistance tight, then a 1/8 to 1/4 turn bump to finish if you don't have a torque wrench.
  5. #19
    CTSM is offline Cadillac Owners Enthusiast
    Automobile(s): CTS 08' 3.6 DI Performance | 07' Lux 3.6 Volant-Borla-Vsways
    Mar 2012
    943
    the main reason why that fill plug's torx hole gets stripped besides from my case (accidentally using a T-44 on a T-45) is due to the fact that if a person is using a ratchet and an extension it's highly likely that the extension will be rubbing against the tunnel insulation which causes the torx bit to be not so flush with the center of the fill plug, which in turn causes the torx hole to get stripped.
    The best way I have found to prevent this from happening is when I was using a 3/8" flexible extension it worked every single time I was able to get the bit centered properly and that flexible extension did a good job not to rub much against the insulation and instead bent around it.
  6. #20
    The Rev is offline Cadillac Owners Member
    Automobile(s): 2007 CTS Luxury
    Oct 2013
    28
    36
    Jim's 06 - I took the allen bolt on the front of the transmission off after reading some threads that mentioned that as the fill plug. I'm dumb enough to stop reading after I read that, but not dumb enough not to remove the fill plug first lol.
    CTSM - thats pretty much what happened to me. I didn't get my T-45 flush and paid the consequences.
    I'm going to heat up the area around the bolt as best I can with a propane torch, then try a flexible extension and get my T-45 flush, hopefully inside I have just a bit more area for it to catch onto.
    If that doesn't work I'll JB weld a nut to the end of it and give it a day or so to cure and try again.
    And lastly, I'll renew my lapsed AAA membership and call a tow to a local shop to have a nut welded on and have them finish the job for me.
    Let me be an example to all, read threads fully if you're not 100%.
  7. Remove Advertisements
