Bad cv axles?
Results 1 to 7 of 7
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Bad cv axles? in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; How can you determine if your cv axles are going bad? I had my tranny rebuilt an new drive shaft ...
    ctsboiha's Avatar
    ctsboiha is offline Cadillac Owners Fanatic
    Automobile(s): cts
    Nov 2012
    29
    114
    Bad cv axles?
    How can you determine if your cv axles are going bad? I had my tranny rebuilt an new drive shaft installed and every time it shifts if feels like it sling shots me into the next year. I don't know where to go from here, so I'm thinking maybe the axles 3.6l is my car anybody?
    DopeEffect's Avatar
    DopeEffect is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 3.6L CTS, Hotchkis Sway Bars, FE2
    Jul 2012
    Dallas, TX
    27
    524
    Re: Bad cv axles?
    Quote Originally Posted by ctsboiha View Post
    Engine mounts. I'm about to get mine replaced because I recently rebuilt my drive shaft and having a similar issue. I'll let you know if that fixes anything.
    ctsboiha's Avatar
    Automobile(s): cts
    Nov 2012
    29
    114
    Quote Originally Posted by DopeEffect View Post
    I replaced my mounts with the ones from rev shift. Same with rear diff bushing an tranny mount an this is still the problem I'm having.
    DopeEffect's Avatar
    Jul 2012
    Dallas, TX
    27
    524
    Re: Bad cv axles?
    What about your flex discs? Did you go with the RevShift flex discs or Creative Steel? The RevShift flex discs require the trans mount to be shimmied/lifted in order for there to be no vibration of any kind. Your driveshaft might also need to be re-balanced. The dealership I took it too did a pretty bad job on balancing the driveshaft. Had to take it to a local shop to get it balanced. Still don't know why the dealership didn't do it properly. It could also be your center support bearing. If you didn't get that replaced in the rebuild, that could also be the cause.
    ctsboiha's Avatar
    Automobile(s): cts
    Nov 2012
    29
    114
    Ya I had a whole new drive shaft put in they said my center bearing was shot an could not separate the shaft so I had to buy a new one an they said they balanced it.
    satlite440 is offline Cadillac Owners Member
    Automobile(s): tec at brotherton cadillac
    Nov 2013
    48
    33
    Re: Bad cv axles?
    did a dealer do this?or an indy??? trans adapts need to be reset after internal repairs... also some older 5&6 spds need to have a fast adapt learn done..
    ctsboiha's Avatar
    Automobile(s): cts
    Nov 2012
    29
    114
    Quote Originally Posted by satlite440 View Post
    Local shop then I had the dealer do a reset
  10. Remove Advertisements
