need a quick answer, which trans cooler line is supply and which is return. !!!
Results 1 to 3 of 3
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, need a quick answer, which trans cooler line is supply and which is return. !!! in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; I need a quick answer, anyone know which cooler line is the supply line and which is the return ? ...
    briggy's Avatar
    briggy is offline Cadillac Owners Enthusiast
    Automobile(s): CTS 3.6L 2005 80,000 Miles
    Dec 2009
    Southern California
    41
    958
    I need a quick answer, anyone know which cooler line is the supply line and which is the return ? Ideally I need to know from the transmission conenction side thanks.
    Iceman_jd's Avatar
    Iceman_jd is offline Cadillac Owners Fanatic
    Automobile(s): 2007 3.6 CTS
    Oct 2012
    Arizona
    112
    Re: need a quick answer, which trans cooler line is supply and which is return. !!!
    Quote Originally Posted by briggy View Post
    Hey Briggy the best way I know is to use a hand held infrared thermometer on the transmission lines after driving it a little while. The hotter one is supply and or the cooler one is return. If you don't have one I know Harbor Freight has them pretty cheap. Found this really cheap one online > http://www.tmart.com/Infrared-Thermo...FYo9Qgodwl0A9Q
    This way at least you'll know for sure.
    Blayne's Avatar
    Blayne is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 CTS sport model/package
    Sep 2012
    Sudbury, Ontario Canada
    1,058
    If its for the external cooler it doesn't really matter. The cooler doesn't have an in and out. As long as the fluid is going through it then it's all good. If it's for another reason then it's as stated above. Heat gun on the two lines at operating temp. Hot line is the outlet if the tranny. If you don't have a heat gun or your car is apart then I can let you know tomorrow. I have an infrared gun and can give you an answer in the morning. Pam me if you need that info.
