Ignition cylinder stuck
Results 1 to 5 of 5
Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Ignition cylinder stuck in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hi, I was trying to remove my ignition cylinder on my '07 CTS so I could take the top and ...
    bhodge is offline Cadillac Owners Member
    Automobile(s): 2007 CTS
    Oct 2013
    Austin, TX
    38
    5
    Hi,
    I was trying to remove my ignition cylinder on my '07 CTS so I could take the top and bottom steering wheel covers off to replace a bad TS switch. I was following this process:
    "Disconnect the negative battery cable. Turn the ignition switch to the START position. Insert the awl into the lower steering column trim cover access hole. Press in the release button using the awl. Release the ignition switch to the RUN position. Remove the ignition lock cylinder."
    However, while doing this after pressing the release button using an awl, I removed pressure from the button before releasing the ignition cylinder. As a result the ignition cylinder moved past start and is now stuck. If the release button is not pushed, I cannot rotate the ignition at all, clockwise or counter. If I push the release button, it pops out, maybe 1/4" to 1/2" at the most and only allows me to rotate clockwise about a quarter turn but does not allow me to pull out the cylinder.
    So now I'm at point where I can't get the key out and the ignition cylinder is stuck in a position slightly past start so I can't even start the car. Does anyone have any ideas on how to get my cylinder back in its proper position? I am about to rip off the bottom cover so I can get access to the switch but not even sure what to do after that. I would think that this might be a semi-regular issue as I could see it easily happening so hopefully there is an easy fix. Any help would be greatly appreciated. Thanks in advance.
    Oct 2013
    Austin, TX
    38
    5
    Re: Ignition cylinder stuck
    I was able to fix this but had to take apart the entire steering wheel column to do so. I will post the process which will include changing out wipers and TS switch as well since they are all accessible during the process. Not difficult if you have the right tools and know where to look but will be a bit time consuming.
    smelcher is offline Cadillac Owners Member
    Automobile(s): CTS
    Jan 2014
    63
    Have the same problem but can't find your post. New to this website.
    Any help will be appreciated.
    bubba1228 is offline Cadillac Owners Member
    Automobile(s): 04 CTS
    Jan 2012
    34
    48
    chucktheduck is offline Cadillac Owners Member
    Automobile(s): 2003 CTS
    Apr 2016
    50
    1
    bhodge....I have the EXACT same problem....attempted to remove ignition cylinder and it turned too far and is now basicall stuck. I cannot get it to move in any direction. I was about to bail and replace the entire column but I saw your post saying you found a solution.
    Care to share?
    Sincerely,
    Aggravated as hell (should have been a simple cylinder replacement)
  8. Remove Advertisements
